Page 2 of 6
Re: sexy beast in progress
Posted: Sat Mar 28, 2015 3:21 pm
by DirtyE
Well it not running, but electrical is in tact and it has fuel/compression and spark.
Posted: Sun Mar 29, 2015 3:16 pm
by DirtyE
Jetting, tranny.. That and a lot more work on the body and im good.
Posted: Sun Mar 29, 2015 3:42 pm
by Rip_City_Spree
Are your front turn signals blacked out? Or smoked?
Posted: Sun Mar 29, 2015 7:29 pm
by DirtyE
I bought that lens tint paint. put like 10 coats on. They look black until they are on. I'll post a pic of one flashing later.
Posted: Sun Mar 29, 2015 7:58 pm
by Rip_City_Spree
Please do I'm curious
Posted: Sun Mar 29, 2015 9:22 pm
by DirtyE
In bed, forgot. Ill get tomorrow. I really does show though nicely....even after like 10 coats.
Ive got a video up of Facebook, the video for YouTube is stuck in pending status.
Posted: Sun Mar 29, 2015 9:35 pm
by DirtyE
Watch "Honda Elite Fabrizi and Yasuni" on YouTube
Honda Elite Fabrizi and Yasuni:
http://youtu.be/rz5YRn0156Q
Posted: Sun Mar 29, 2015 9:54 pm
by Rip_City_Spree
Worked for me she looks great like the blue.
Posted: Mon Mar 30, 2015 8:36 pm
by DirtyE
http://vid1077.photobucket.com/albums/w ... egowkm.mp4
Rip city, you asked about the lens tint paint. I really put like 10 coats on to make them BLACK!
Posted: Mon Mar 30, 2015 9:01 pm
by Rip_City_Spree
Awesome actually quite bright still. I think I need to do that to mine.
Posted: Mon Mar 30, 2015 9:26 pm
by whitey
That's looking sweet. The black lenses are cool.
Posted: Tue Mar 31, 2015 10:04 am
by Mini_Stroker305
DirtyE wrote:Well it not running, but electrical is in tact and it has fuel/compression and spark.
I dig it my man nice ride !
Dirtys Elite
Posted: Tue Mar 31, 2015 12:58 pm
by DirtyE
You can barely see in my YouTube video that I changed the bulbs in my dash from standard yellowish white to blue. Im going to rewire the dash lights to the dc circuit so theyre always bright.
Posted: Fri Apr 03, 2015 5:42 pm
by DirtyE
Spent the day tuning today. My car was broken into and my bag for work was stolen, so I took the day off.
Results from a day of tuning:
I started off with stock rear gears and 5.0g rollers. It was quite zippy up to about 35mph, but was revving out of its mind. I went to 5.5g rollers, that brought down the 35mph overrev, but not enough. Next I put in the 9:1 gears and took the 5.5 out, replaced them with 4.5g rollers. Nice and zippy off the line, good RPM level at 35-45 cruising range as well(not overreving to the moon and weak anymore).
I am most certain at this point I need a stiffer than Blue torque spring, and to stiffen my clutch springs. I could use a little bit higher RPM on the clutch grab, and I get a midrange bog that eventually evens out.
My carb is dialed in for the most part as well. The 45 pilot jet is very responisive to the airscrew, revving highest in between 1 and 2 turns out. I'm satisfied there. I was running the largest main jet that I had at a 118, and it was still lean after a large jump from 105. I borrowed a 130 jet from Whitey and WOT is very smooth and solid. I haven't given it enough WOT throttle time to plug chop WOT. I still need to adjust my needle to the proper position. It was in the middle, but after running at high speed it would hold rpm for a few seconds. I thought this was a lean condition, so I lowered the clip a notch, to my surprise this made it worse. May be an issue with diameter I suppose. I'm going to move it 2 up to see if I was interpreting the mis-performance incorrectly.
I'm very pleased with the progress made today. With the performance im getting at this point, i'm pretty eager to see how much more I can squeeze out. i'll be ordering 3.5g rollers and a malossi red torque spring for testing. I assume that 3.5 will be too light, but I can mix them with the 4.5g and get 4. When I get it dialed in the way I like, I will post a video, and make a game out of it. Guess the RPM by its sound..
Im tuning without tach or temp, so it will be a mystery to me as well. I'll then get whiteys nice stuff like tach and temp and we will all see what RPM I am running.
Posted: Sat Apr 04, 2015 3:38 am
by ped
Hi Dirty. the scooter came out very nice. I'm loving that satin pearl blue
