Page 2 of 2
Re: yasuni c16 owners "top speeds"
Posted: Tue May 19, 2015 1:48 am
by 1man8scoots
What needle are you using? I'm running a jjh in one 26 and stock polini needle and I swear the jjh made it run leaner. It is a tiny bit fatter but its a lot leaner.
Posted: Tue May 19, 2015 3:56 am
by jetlag
It is a jjh needle and the clip is one below the middle so I have to go back to the stock needle that came with the polini 24pwk which has a thinner tapper "richer" so I'll either be in the middle or second from the top and maybe even go lower on main since I still didn't even break 350 on wot but I just had enough tuning for now.
Posted: Tue May 19, 2015 4:05 am
by jetlag
If I had my 8.4 gearing that would put me in 11k but my mhr wasn't making good power there, 10k range is the happy place anything in the 11s was more like reving than moving and just using more gas. Next build will be the polini corsa and I think this should match the pipe better but will see haven't build a polini in 10 years no short cuts on this one since the block I'm using now just has the boost to match and nothing else touched
Posted: Tue May 19, 2015 7:09 pm
If that temp can be assumed to be accurate, 71+ is all the more remarkable because it's pretty rich and thus down on power. Drop a jet size and see?
Posted: Thu May 21, 2015 5:29 am
by kauaianman
try to experiment with 28 carb. if you have 1 laying around that is.
and, i know....... i know........ BUT!
you never know unless U try
