Wheel options for a 96' Elite SR?
Ambientek
Re: Wheel options for a 96' Elite SR?
Post by Ambientek »
Got the wheel tonight! Battling a migraine atm. Ill know more tomorrow.
Picture of wheel it's splines and max dia.
http://imgur.com/yyRapgp
Open comments pertaining to my scooter are entertained and promoted by me.
Ambientek
Post by Ambientek »
Thanks for the help guys! :rock: Just ordered a 90/90-10 for this puppy.
1man8scoots
Post by 1man8scoots »
Fits like a glove right.
Clean out that tire slime ha.
Ambientek
Post by Ambientek »
Yeah that's exactly what I was thinking. Theres absolutley no way to do a Douglas wheel conversion without modifying the shock. Thats assuming their narrowest wheel is a 2+2in.
Although you might be able to put a half inch spacer between the Kymco adapter the 4" douglas wheel just enough to keep away from the shock and still squeeze it within the muffler.
Thanks! :bowrofl:
Ambientek
Post by Ambientek »
Got the tire in today. Decided to go with a 90/90-10 Kenda K329.
http://i.imgur.com/cI3T1n9.jpg
http://i.imgur.com/JEn1x9G.jpg
Ambientek
Post by Ambientek »
Update:
Drove it up the rode a few times turns out the tire is infact rubbing the spring. Not quite sure what would my options are now.
Everything stock even the rollers except KOSO variator and back wheel at this point.
You can see the mark on the tire
Ambientek
Post by Ambientek »
Solution(?):
rotated spring ~a half turn. If that ain't about a beesdick of space i don't know what is.
curtis966
Post by curtis966 »
Yeah that will rub under load for sure. If you take the rim off and put a thick washer on the axel then the rim you can get a little more clearance.
Johnniespeed
Post by Johnniespeed »
Why not move the shock away from the tire ? Reshape the lower shock brackets and modify the upper frame. A quarter inch should do it.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Ambientek
Post by Ambientek »
I reacted a little hasty perhaps. I ended up taking the spring off and sticking it in the vice and bending inbetween the 3rd and 4th turn from the botton. I threw a zip tie around a couple of spots to maybe hinder it from turning too much to let it end up in a bad spot. Sat pretty firmly without the ties. I definitely will do this the correct way as soon as I source a spring.
