2000 Japan Jog
MrJumps
Re: 2000 Japan Jog
Post by MrJumps »
graphite9 wrote:
MrJumps wrote:Maybe its me, but I always seem to thing the polini carbs look crap cased on a picture. I know they are good carbs, but the oko ones look better on pictures. Maybe I am just crazy. Make me wanna buy a Jog now though. Read somewhere you can bbk them to almost 20hp. Thats bloody nuts, the nuts I like to be.
no you have it backwards. They are ten times a OKO. Oko's are seriously the cheapest carbs on the market for a reason. You could get two, and one would require a bigger Mj than the other. THey suck, ask anyone who has ran them both. The oko probably cost $10 to make in china..Think about that one
I wasnt saying the polini is bad it just lookes like it in pictures, i personaly prefer fuel injection over carb so I dont have a full grasp on the brands but polini seems to be the most choosen.
2021 DRZ400sm :worship:
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
Spark plug turn out nice color after 2nd run.
2016-02-02 05.53.23.jpg (200.29 KiB) Viewed 22549 times
Meloshameless
Re: 2000 Japan Jog
Post by Meloshameless »
That jog is gonna tear a**! Always been my favorite bike! Just cant find em on the mainland, not Or anyway.. you gotta stop by motosource and show it off, they'll really appreciate a bike and build like that. The owners brother took my Razz from 32 to 50 just by modifying stock and adding a carb! Good set of guys.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
Japan tail came in mail today.
2016-02-08 20.31.05.jpg (35.74 KiB) Viewed 22530 times
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
I did compression test. :mrgreen:
2016-02-10 21.31.21.jpg (110.03 KiB) Viewed 22513 times
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
Today, I put in the new bore top performance blk trophy ,ran stock carb 14mm 48 pilot and main jet 110 32:1 premix. I rode 5 miles and runs great! :mrgreen:
2016-04-23 09.14.27.jpg (131.16 KiB) Viewed 22463 times
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
I did 30 miles riding since had a new bore and check compression last night. It had 164 psi on cold engine before riding my jog.
2016-04-26 21.08.28.jpg (36.9 KiB) Viewed 22443 times
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
motor still going strong had 50 miles on it , i did wide open throttle 1/4 miles. reliable 1 kick start , motor runs.. :mrgreen:
Re: 2000 Japan Jog
Hope you run race fuel or AvGas.
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
im using 92 gas tesoro, 76, chevron.
Re: 2000 Japan Jog
Hmm, don't know if a drop from 171 to 166 is significant or not. Hope it's ok, but I'd add a gasket or trim the head to lower compression to 145 if it were mine. Either that or race fuel.
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
compression 171 is polini corsa w/ oring corsa cylinder head and oversize malossi piston 47.8mm, base paper gaskets
Compression 164 is top performance black trophy, asso 47mm piston, both aluminum gasket.
Re: 2000 Japan Jog
I'm just not sure if even the precise, high-quality Corsa can survive with that compression on pump gas.
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
corsa bore still can handle on 92 gas.
veedubh20
Re: 2000 Japan Jog
Post by veedubh20 »
Here is my daily riding. :coolcruise:
2016-05-24 16.48.20.jpg (161.11 KiB) Viewed 22416 times
