My new Dio
whatever, you dont know shet, nextime you bring in your broken exhaust I make sure I weld em real good for Umaddog wrote:I know who Frank buys from stroka! and it ain't youits what you don't kmow that i do!
And frank buy's from alot of people, different parts from different people you dumbass.
- BigWillieStyles
- BMX
- hrnytrtlsgsxr
I just want to back hand his * like the beoch he hishrnytrtlsgsxr wrote:like strokah said he buys from several people. you know of only one. maybe the only one you know of starts with an M but there are more out there.maddog wrote:I know who Frank buys from stroka! and it ain't youits what you don't kmow that i do!
- BigWillieStyles
- BMX
Hey guys i tried to get some clutch springs from from my local shop but they reckon they dont make clutch springs for the Live Dio J model? I find this hard to believe. Why would the springs be any different from other engines, surely honda used the same clutch kit for all Dios right?
Any help would be appreciated.
In better news i got a new CDi i will plug in soon.
- BigWillieStyles
- BMX
- BigWillieStyles
- BMX
no that's idle, the one above and to the right is the a/f screwBigWillieStyles wrote:Hold on i will do it now
This last one, can you see through the gap in the plastic is that the Jet? The little bronze screw?
As for the rear drive it looks like a 3 clutch setup ,but not totally sure, J means drum brake but am not sure if it uses the dio fit style rear clutch setup. I know that the J is the cheapest -af34
Honda Motor Co., Ltd. (Inc.), the beginner as [metsutoinsukuta] ├óÔé¼┼ôDio├óÔé¼┬Ø of 50cc which is regularly used in from the first wide layer and ├óÔé¼┼ôDio ZX├óÔé¼┬Ø are changed minor, it types adds ├óÔé¼┼ôDio J├óÔé¼┬Ø of the price which it is easy to seek, makes the respective domestic new exhaust emission standards conform and sells from September 14th.
This Dio is the model which obtains favorable comment in wide layer e.g., the sum total sale quantity of the series 2,800,000 * breaks 'the first model since selling, with the body size and the engine etc of strong output characteristics where the routing is good, in the country in 88.
 As this time, both 3 models, setting of the carburetor is modified, the oxidation catalyst ([kiyataraiza]) by the fact that you adopt, it has made domestic new exhaust emission standards conform inside the muffler.
 * 1999 8 end of the month presently. (HONDA you inspect.)
Dio Dio ZX
- Sales planning quantity (domestic year) Series total 120,000 units
- Manufacturer desired retail price Dio J 144,000 Yen
Dio 157,000 Yen
Dio ZX 179,000 Yen
 (One example of regional desired retail price: As for Hokkaido 8,000 increases in yen value, as for Okinawa 5,000 increases in yen value. In addition part area is excluded.)
 (Reference price. Consumer tax it is not included.)
Modification point of = latest model (series commonness) =
● It modifies the setting of the carburetor, inside the muffler the oxidation catalyst ([kiyataraiza]) it assures the reduction of CO and HC by the fact that you adopt, has made domestic new exhaust emission standards conform.
● By the fact that structure of the muffler is modified, it has made domestic new noise regulation conform.
Main modification point = of = each model
◎Dio
 Enlargement of [riakiyaria].
 Color modification of bottom case section of [hurontohuoku].
 Form modification of [mahurapurotekuta].
◎Dio ZX
 Adoption of rear spoiler of [sukerutontaipu].
Dio J which this time anew it types sets, Dio in the base, has modified the front brake in the drum.
= From the past main merit =  [metsutoinsupesu] which can receive [huruhueisuherumetsuto] and the like.
 The effective center stand to the control of robbery can be locked ├óÔé¼┼ôlockin mechanism├óÔé¼┬Ø.
 Fuel tank of bulk 6.0L.
 Front & rear tubeless tire
 Simple obtaining effective damping force with operation before rear wheel gearing brake ├óÔé¼┼ôcombination brake├óÔé¼┬Ø
  System. (The installing only Dio)
= Color variation = Type Body color
Dio J Plain gauze star white Black
Dio Paw ceric silver metallic Candy glory lead-lead
[be] [gaburatsukumetaritsuku]
Dio ZX Pure black [bunshirubametaritsuku]
Pearl sea shell white
Leading particular Alias name
Dio Dio J Dio ZX
Car name type
HONDA BB-AF35 HONDA BB-AF34 HONDA BB-AF35
Total length ## full ## total height (m)
1.675├âÔÇö0.625├âÔÇö
0.995 1.675├âÔÇö0.615├âÔÇö
0.995 1.675├âÔÇö0.630├âÔÇö
0.995
Wheel base (m)
1.145
Roadspace (m)
0.105
Seat high (m)
0.700
Vehicle weight/dry weight (kg)
75/69 73/67 75/69
Riding in a car fixed capacity (person)
1
Fuel consumption rate (km/L)
(30km/h fixed area travelling test value)
49.0
Minimum turning radius (m)
1.80
Engine type
AF34E air cooled 2 stroke one cylinder
Total cubic displacement (cm3)
49
Inside diameter ## distance (mm)
40.0├âÔÇö39.3
Compression ratio
7.1
The highest output (PS/rpm)
5.6/6,500 6.3/7,000
Largest torque (kgm/rpm)
0.64/6,000 0.66/6,500
Carburetor type
APBC
Starting system
Self system (kick type establishment)
Ignition system
CDI type magnetic ignition
Lubricating system
Separate oiling system system
Lube capacity (L)
1.3
Fuel tank capacity (L)
6.0
Clutch type
Dry multiple plate shoe systems
Transmission type
Variable speed system (V matic)
Change gear ratio
1st gear
2.450~0.850 2.850~0.860
Caster (degree)/trail (mm)
25├é┬░40′/72
Tire size
Before
3.00- 1042 J 90/90- 1050 J
After
Brake type
Before
Hydraulic type disk Mechanical cable type leading
Trailing Hydraulic type disk
After
Mechanical cable type leading trailing
Suspension system
Before
Telescopic system
After
Unit swing system
Frame type
Under bone
Dio Dio ZX
Dio 157,000 Yen
Dio ZX 179,000 Yen
◎Dio
◎Dio ZX
Dio Dio J Dio ZX
Car name type
0.995
Wheel base (m)
1.145
Roadspace (m)
0.105
Seat high (m)
0.700
75/69 73/67 75/69
1
49.0
1.80
Engine type
49
40.0├âÔÇö39.3
Compression ratio
7.1
5.6/6,500 6.3/7,000
Carburetor type
APBC
Starting system
Ignition system
Lubricating system
Lube capacity (L)
1.3
6.0
Clutch type
Transmission type
Change gear ratio
1st gear
25├é┬░40′/72
Tire size
Before
After
Brake type
Before
After
Suspension system
Before
Telescopic system
After
Unit swing system
Frame type
Under bone
