Re: Losses some power when hot, possible leak?
Posted: Thu May 26, 2016 4:25 pm
OK, so maybe we should define terms. I assume it's running Badly. Lean and Rich both feel ... Bad. The distinction in "Bad" is found in Operating Temperature (Rich = cooler, Lean = warmer), carbon deposits when rich (on the plug but also anywhere else in contact with spent fuel...), or dry, pale scorched surfaces, Rich = runs better with engine cold (and cooler ambient temps, lower humidity, etc) If you had a stock bystarter, I could see your engine is too lean but runs right as long as the bystarter is adding mixture. But since you have a manual enrichener, and just about every symptom points to rich, it's not clear why you insist it must be lean. A functional temperature gauge would help further diagnose this mystery.
