nice idea, will try this. thanksMrJumps wrote:Place a vacume cap on it thats a size smaller than the pipe for a very tight fit. Then heat srink over the edge of it. Thats probably the cheapiest and easiest way to do it. And it dosnt envolve filling with resin. The bolt in the line will leak over time. Vaccume cap is like 2.50 usd and the heat shrink at walmart is 6.50usd or you could use a wire clamp, ziptie, etc.
pretty sure one of these will fit
http://www.autozone.com/ignition-tune-u ... ckfit=true
