hello all im backkkk
- swimmingfree
Re: hello all im backkkk
Hay guys looking for something or info... the pin that comes down on the carb what is it called or if someone has one for a 1994 fa16 stoc
For a stock carb... will the pin on the slide from a spree be the same???
Thank for your time
Swimmingfree w
Thank for your time
Swimmingfree w
Spree carb probably not the same. It’s called a jet needle. I have one I can send you with the e-clip. PM your address to me Greg I will get it out today.
- swimmingfree
Sent it to you...
Thank you for the help
Swimmingfree
Swimmingfree
- swimmingfree
did you get the money???
I did. Thank you! Did the part work?
- swimmingfree
dont no yet its at my sun place its a father and son thing ever the father is 60 and the son is 32 lol ... we just got my son jeep done so he can play in the sand with it....
- swimmingfree
Hay all got it home and running now all's well with it wood like to get a exter key for it some input on where to fine one for my 94 elite wood be nice..
Thanks for your time
Swimmingfree
Swimmingfree
- nateberrier
taz sells slow jets on ebay for these, youll have to yank it out with a pair of needle nose, then heat the carb body up in the oven at ~200 degrees, stick the jet in the freezer, then jam it in, some petroleum jelly might help i dunno. I upped mine to a 40swimmingfree wrote: Sat Jun 15, 2019 9:09 pm Went to my son's place were my 94 elite is and play with the carb today the jet was 78 we up jetted to 82... I think the pin is the slow jet was bent I'm looking for one if some one has one and willing to sell it let me no..
Thanks for your time..
Swimmingfree
1986 Aero White -- Stock With Keli Var
1985 Aero Red -- Af05 Malossi BBK + Keli Var
1985 Aero Red -- Af16 Corsa / Fabrizi Pipe / Polini 24 PWK / Athena Stuffer Crank
- swimmingfree
ok guys im looking for one thing... its a graph on the jets of a carb .... does some one have it still...?
thanks for your time
what is stock sizes on pilot jets on af16 carbs, i dont know if this is the right place to ask it. for the sr model or sa50 not p/sa50p.nateberrier wrote: Tue Sep 10, 2019 9:36 amtaz sells slow jets on ebay for these, youll have to yank it out with a pair of needle nose, then heat the carb body up in the oven at ~200 degrees, stick the jet in the freezer, then jam it in, some petroleum jelly might help i dunno. I upped mine to a 40swimmingfree wrote: Sat Jun 15, 2019 9:09 pm Went to my son's place were my 94 elite is and play with the carb today the jet was 78 we up jetted to 82... I think the pin is the slow jet was bent I'm looking for one if some one has one and willing to sell it let me no..
Swimmingfree
heres a pic, the top left shows some info on what the jets are and where they affect throttle for another carb.
- needle chart specs.jpg (69.69 KiB) Viewed 25469 times
- swimmingfree
im looking for a little help from you guys .... what size tire on your af05 moter
thank for your time
thank for your time
hello greg, if it’s a se50 or sa50 the tire size is 3.00x10 but I’m not sure about a spree “af05”swimmingfree wrote: Sun Mar 29, 2020 6:47 am im looking for a little help from you guys .... what size tire on your af05 moter
thank for your time
The Spree comes equipped with 2.50x10
- swimmingfree
Thank for the Info on the af05....
How about this one...
Af16 polini 72 jug and a polini 24 carb what size main jet shood I get??? 105 is in it now.. try to get a hold of scooter swap shop and its a no go can't get throw... that don't have then in stock for the carb....
Thank for your time
Swimmingfree .
Thank for your time
Swimmingfree .
I’ve seen between 108 and 118
It would also depend if you have air filter or not and what type air filter. You need to use a cht temp gauge to dial it in greg.
I get jets from jetsrus.com in Wisconsin
Reasonably fast shipping w/good prices and choice of oem or aftermarket jets for most all carbs
