I have a couple other threads on here for various tuning and disk build out.
Since I last posted on this one, I have done quite a bit.
I added a hella supertone horn for good measure,
Disk brakes / forks / custom stem / etc
ZX trans, and its mostly dialed in at this point.
6.8g weights, Keli Variator with SEF plate, 1.5k malossi contra, and malossi ZX belt.
I am running 9.8:1 gears and I can hit about 62 mph in short order, I know everyone goes taller, but I doubt if I ever will.
I also added a cheap Ebay light that was small enough to fit in the stock opening, so I might see at night.
Had to import some Live Dio wheels from Japan and paired them with 90/90 michelin S1 tires.
Went with 200mm disk brake and what I assume is a kymco agility caliper. Got an adapter from someone in Taiwan.
Have moved to doing small appearance tweaks, probably will progress over the summer until the COVID is gone and i can get a motorcycle.
