1987 Honda Elite SE50 Derestricting
Honda50
Re: 1987 Honda Elite SE50 Derestricting
Post by Honda50 »
Not to hijack this thread, but I’ve been digging through my stuff this morning as I’m piecing a variated AF05E swapped Spree together. I have an AF05E from a 90’s SA50. It looks like the stock SE50 pipe I have laying around will bolt on. I also have an unrestricted SE50 pipe. Question is, which pipe will work better with the stock carb that came with my engine?
Brivander
Post by Brivander »
Use the unrestricted pipe, if it is from and Elite S or an Aero. You can’t unrestrict the restricted pipe (easily), there is no washer.
1985 Black/Purple Spree-39 GPS
1985 Red/White Spree-40 GPS
1987 Black/Purple Elite-44 GPS
1985 Red/Black Aero-42 GPS
1992 Red/Gray Jog- 56 GPS
Brivander
Post by Brivander »
Oh, if you go unrestricted, make sure you jet up from the stock 82 to 84-86.
Honda50
Post by Honda50 »
Thanks for the info. What size jet did my SA50 come with?
Brivander
Post by Brivander »
Honda50 wrote: Sun Oct 20, 2019 6:14 pm Thanks for the info. What size jet did my SA50 come with?
I assume the restricted version is the same as mine, 82. When I was doing the same thing, I swapped to the unrestricted size (Elite S or Elite R in 1987), which is 85, but I only had 84 and 86.
Brivander
Post by Brivander »
The mystical Elite S Driveshaft. Now I need to find one more for my Aero!!!
