Page 2 of 3
Posted: Sat May 26, 2007 11:14 am
by Dac
Son of a b**** she runs again!!!!!!!!
i got the rings on after the 3rd try, got it all back together and now she runs great.
the Take off is amazing but the top end is lacking (like 35) any idea or is this all she is going to do ?
(also thanks every one for all the help)
Posted: Sat May 26, 2007 12:21 pm
by Kenny_McCormic
idk s*** about elites. does the variator have a restrictor in it?
Posted: Fri Jun 01, 2007 8:34 pm
by Dac
some one shoot me in the head.... :evil: :evil: :evil:
ok so i had it running, running great like 37 top speed and amazing take off.
so today after riding it top speed for about 2 hours it sputtered and died. it die like an 'out of gas' die, but i have a almost full tank. now when i kick it , it dose nothing at alll. like theres no gas or spark... BUT THERE IS BOTH
there has been something up with the carb or something; my air filter (dirt bike pod) has been covered in oil to the point of dripping on my motor for about a week or two. i took it off and cleaned it 2-3 days ago and over night it got back to all wet. it was something i just never got around to fixing.
before ridding it today it was fine, i put some oil in it,gassed it up and it ran fine. when riding it was doing great all up to when it died
any ideas any one?
Posted: Wed Jun 06, 2007 5:14 pm
by MySpree
you didnt break in the engine, it might of blew.
Posted: Wed Jun 06, 2007 8:38 pm
by Dac
what do you mean by that?????
i have it torn apart agian and im going crazy
great spark, 70psi compression , clean carb. , has gas WHATS WRONG??????????????????
Posted: Wed Jun 06, 2007 9:53 pm
by Kenny_McCormic
bad head gasket? impropery tored head bolts? i dunno if i were you i wiuld completly strip down the engine split the case and everything
Posted: Wed Jun 06, 2007 11:05 pm
by scooterpoot
You may have fouled the spark plug. I would try a new one before you start taking things apart.
Posted: Wed Jun 06, 2007 11:30 pm
by Dac
i have 3 plugs that are all dark but have great white spark
im going crazy... is there any type of timing that could be off?
is there timing on a moped?
when im trying to start it,it will get so close and it just wont start, it spits ,sputters and will start for about half a second then nothing
Posted: Thu Jun 07, 2007 5:42 am
by Gamemedic
A few things to check:
1. What is your compression spost to be, 70psi sounds low.
2. You should have a nice blue spark, white or yellow spark is weak.
3. You prob. have a case leak, thats why you were going so fast, 37mph is way fast. Remember "lean is mean" you prob burnt her up. Also a lean mix, or low compression is very hard to get started.
4. Put in a NEW plug, stop the fuel flow and drain the carb. Crank the bike over for 10 sec then shoot starting fluid in the carb and see if it starts. If it does then you are lean or low compression.
Posted: Thu Jun 07, 2007 12:23 pm
by Dac
Gamemedic wrote:A few things to check:
1. 70 psi is good for mine,before when the rings were broke i got 20
2. i get a great white blue spark, yellow or red is bad,white is good isnt it?
3. 37 isnt that fast , the people i bought it from and there friends said it did like 40-43 mph. plus till this happen it started first kick every time
is it possible that the case cracked when i was riding? i didnt see any trail of oil or anything how ever for that last 5-10 minutes it seemed my take off was slightly better
4. ill try that , thanks for the comment and the help
Posted: Thu Jun 07, 2007 1:22 pm
by Farfignugin
Yea, white is much hotter than blue. Spark or flame heat goes orange/red<blue/yellow<<white. Anything white is quite hot.
Posted: Thu Jun 07, 2007 3:44 pm
by Gamemedic
Check your spark plug gap. If you are getting a true white spark then you might have the gap to tight. Your bike should only produce enough voltage to create a blue spark across the gap. Have you tried a new CDI box? It might be creating to much dwell and changing your timing. The extra saturation time would create a white spark.
Posted: Thu Jun 07, 2007 5:42 pm
by Dac
the gap might be off ill check that in a bit, i still havnt done anything with it today
Posted: Fri Jun 08, 2007 4:36 am
by stillspeeding
70 psi will never start a 2 stroke! learn how to use your guage!?#*
Posted: Fri Jun 08, 2007 4:06 pm
by Kenny_McCormic
some gauges read low on tiny little engines
