Page 2 of 2
Re: 85 Spree - Not enough power to turn over fast enough
Posted: Wed Oct 27, 2021 7:39 pm
If the starter works correctly, and the gear teeth mismatch isn't the issue, could something be making the engine itself harder to spin? If your battery is still suspect, jump it to a car battery and see about that.
Posted: Wed Oct 27, 2021 9:15 pm
by Rideslikenacho
Wheelman-111 wrote: Wed Oct 27, 2021 7:39 pm Greetings:
So I can crank it up pretty easily using a drill and 17mm socket. So I’m thinking that the crank bearings, etc are good.
Jumping it from the truck I’ve tried putting the leads directly to the battery, removing the spree battery leads and putting jumper leads directly to those, and disconnecting the starter harness and connecting jumper leads directly to that. This was all prior to taking the starter in for repair and I also had the crank case side off. I’ll try that again if it still has a binding issue when I get the starter back in it.
Posted: Sat Oct 30, 2021 2:07 pm
by Rideslikenacho
Anyone know if this washer #6 in the diagram is the one that holds the bendix together or separate?
Posted: Sun Oct 31, 2021 3:19 pm
It does look to be a unique part.
The washer on the Bendix is counterbored to house the retaining ring on the Bendix shaft.
But the parts fiche description is WASHER, PLAIN (10mm) 90401-437-000. A photo(found on eBay) shows a plain washer.
Posted: Mon Nov 01, 2021 6:10 pm
by Rideslikenacho
mousewheels wrote: Wed Oct 27, 2021 6:17 pm
So I counted 65teeth on the bendix which seems to be correct. Waiting on getting the starter back from the repair shop to count those splines.
Good you have the correct Bendix for your model. I hope your starter is 10T and is soon back in shape :thumbwink:
Alright well bad news the starter has 11 splines which is the later version. Which sounds like is not compatible with the 65T bendix I have. Question now is, is it better to get a 10T starter and possibly get a dud, or find a bendix thats compatible with this starter? That’s assuming the newer starter/bendix combo will work in the older 85 model.
Posted: Tue Nov 02, 2021 1:10 am
Rats!
It only an opinion - Shop around for a 10T starter from a trusted trader. You have a service shop checked out 11T starter that should be sought after.
If the 10T's armature is ok, anything else - brushes/bearing/bushing is small stuff that will renew the rest.
Posted: Tue Nov 02, 2021 7:23 am
by Rideslikenacho
mousewheels wrote: Tue Nov 02, 2021 1:10 am
Rats!
Yeah dissappointing
So I searched a bit online last night and was unable to find a decent priced 85 starter. Ordered a bendix for an 86 with 63T that ‘should’ be compatible with this starter. It’s a good test to see if that actually fixes the issue. Unless the newer bendix itself doesn’t fit in the 85 it should work. Worth a shot. If not I’m open to ideas on where to find a 85 starter.
Posted: Wed Nov 03, 2021 10:50 am
True - that will be helpful work on the issue
Posted: Sat Nov 06, 2021 4:16 pm
by Rideslikenacho
mousewheels wrote: Wed Nov 03, 2021 10:50 am
Quick update:
The newer model bendix (86 and up) with 63T ‘DOES’ work with the newer model starter 11T (86 and up) in the 85 model Spree.
Put it in and it spins over without the binding issue as seen before. Thats the good news, bad news is I ran the battery down before seeing it fire at all. Not sure if it wasn’t spinning fast enough to crank it, but charging the battery and will try again.
Other good news is while waiting for the bendix I replaced both left and right crank seals and cleaned all the surface rust from the flywheel. Also removed all the oily gunk buildup behind the stator and some small rust from the metal contacts on the stator itself.
Posted: Sat Nov 06, 2021 6:26 pm
by Rideslikenacho
Quick update:
Jumped it off the truck, sprayed it twice with starter fluid in the airbox and it fired up, made some adjustments to the idle and air mixture screw and let it idle for a good 20 minutes. Then rode around the backyard a few times. Turned it off and it cranked right up with the battery. Did that a few times and cranked right up. Will try again tomorrow after its sat overnight and see what happens.
Posted: Sun Nov 07, 2021 12:30 pm
by Rideslikenacho
No start condition today. Will run a few seconds on starter fluid then die out. Definitely seems like fuel is not being delivered. Definitely it making it to the carb so new petcock is good.
Pulled the bystarter to check condition and it was stuck inside the hole. Went ahead and ordered a new one.
