85' Spree fires up then dies
Rideslikenacho
Re: 85' Spree fires up then dies
Post by Rideslikenacho »
I’d be curious if a ball valve with pod air filter could be fabricated to replace the stock airbox.
Heni
Two bystarters, one reading 15 ohms and one 17ohm when manual says 10ohms maxs
Post by Heni »
Wondering whether these cheapo bystarters are safe to put on a Nifty50/Spree 1986. The manual says 10 ohms max but these generic Nq50cc bystarters are about 15 ohms. I notice the inside of the bystarter cavity where the needle sits and blocks the bystarter jet when hot is showing a bit of wear. Probably not the perfect seat. Does it matter? Do the ohms matter?
