1985 Spree - Carb not pulling vacuum
Rideslikenacho
Re: 1985 Spree - Carb not pulling vacuum
Post by Rideslikenacho »
Wheelman-111 wrote: Tue Nov 30, 2021 6:58 pm Greetings:
Glad you got it running! I'd suggest you put your stock carb and all its parts in a can of Berryman's for a few months. It'll come out clean, and ready to replace the Clone carb when it fouls up...
So originally I was going to use the orm carb but the threads were stripped out entirely. So I rethreaded to a size M10, and in doing so did not consider the hole size on the intake and also carb insulator gasket. So to reuse it now will need another intake and gasket and drill those to the M8 size.
