What type of Oil do you run and what muffler type?
If your mufflers clean.....I hate to say sounds like Piston/Cyl damage...Oil injector (pump) out?
72cc bore kit and other mods, was doing 59ish, now 46
- Crotchrocket
- BMX
- islandbayy
Auctually i put my old bore in, and it does same thing. Not the piston then. Compression is awesome.
Stock muffler. Decarbonized in grill and with a MAPP Gas Torch. It is thourly clan.
Honda Genuine 2 stroke oil
http://KmanScooters.com
http://MilwaukeeEV.com
Leak
Check for an air leak in the intake system. Try using a propane torch that's un lit and aim it at the intake gaskets around the reed and the carb to see if the engine speed changes at all. If so then you found your problem.
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
Malossi 72cc Bore
Phongeer Long
9 to 1 Gears
Parmakit Variator
- Crotchrocket
- BMX
