Page 2 of 2
Posted: Tue Jun 05, 2007 4:27 pm
by Kenny_McCormic
you will probably not need a cycle license depends on the state. there is an air filter take the side panls off and you will see a big black box sitting above therear wheel the filter is in there. painting it will be fine just tell them aout it when you get the title
Spreewell wrote:All ya have to do is outrun da feds when they come after ya, don't waste your money on registration.
iwill laugh if a week later you come complaning about how you got some huge fine for not havinga registered bike. and there is no way a spree can outrun a 350v8 so stfu
Posted: Tue Jun 05, 2007 6:11 pm
by ricky1022
ok i got the new batt and now it wont start again, i think its the alternator, where can i get one? the batt doesn't stay charged, it dies
Posted: Tue Jun 05, 2007 7:21 pm
by Kenny_McCormic
does the headlight work when you fire up the bike if it does the stator is fine try charging it up on a charger then putting in the bike and ride it for at least a half hour the little stator can only charge so fast. you also may have a bad rectifier i would change out the rectifier first
Posted: Wed Jun 06, 2007 7:39 am
by ricky1022
so just ride it for like half an hour and it should be ok? i ran it for like 2 hours a couple of years ago and it did nothing, where can i get a retifier and how much are they
Posted: Wed Jun 06, 2007 4:15 pm
by Kenny_McCormic
if the lights are still working its definitly a bad rectifier or a loose wire somewhere try starting the bike with no battery and hook up a multimeter to the wires is it reading a steady 10-15 volts or is the needle all over the place?
you can buy a recyifier from a honda powersports dealer basically anybody that sells honda quads, dirt bikes or street motorcycles should be able to get you one shouldnt be mor than like $20 you can test the rectifier to see if its good by hooking up a continuity to it because the rectifier is just 4 diode all hooked togeher with the arrows running in the same direction.
Posted: Wed Jun 06, 2007 5:39 pm
by chevyguyjay
i have one from a 87 honda spree. if u still need it, make me an offer.
Posted: Thu Jun 07, 2007 8:26 am
by ricky1022
nah, if it doesn't work by sunday im just gonna part it out, also the i checked the air filter and it disintegrated , it was just little pieces of foam covered in what felt like oil but came off easy, would that have something to do with not starting??
Posted: Thu Jun 07, 2007 8:28 am
by ricky1022
oh and when the key is in the back light is on and when i turn it on (when it does) the front one goes on, the horn and blinkers work when its not on, and when i had to push it home from last time i was able to start it up fine once but then after that again, no juice
Posted: Thu Jun 14, 2007 5:37 pm
by spree nut
Check all your wires and make sure none are corroded
