Honda SA50 Headlight Replacement?
Rideslikenacho
Re: Honda SA50 Headlight Replacement?
Post by Rideslikenacho »
noiseguy wrote: Mon Oct 16, 2023 9:44 am
You can 100pct take a dremel with cutting wheel to the bulb, cut/smash out the internal bulb, and replace it with a 25W halogen or LED unit held in place with putty epoxy i.e. JB Weld.
I may try this on one just to see how it works.
bonesv
Post by bonesv »
I just remembered I saw a guy use a spree headlight on his sa50 elite - so I suppose you could also? It kinda sits back inside the cowl and is flat-faced but it works - I have seen it myself. I do not know of what modifications he had to do to make it work tho....
Rideslikenacho
Does anyone know how many wires the headlight harness has? Trying to figure out how many connections a 25 watt halogen bulb should have to swap one.
3. Ground, High, Low.
