Page 2 of 2
Posted: Sun Sep 09, 2007 4:50 am
by jeremydde
diomike wrote:i find that after owning a dio they tend to be unstable. my dio ran for a 3 weeks straight and now i cant get it to turn over. i cant figure the problem out
Really? I have never had any major problem with mine. Mine had a dirty carb when I bought it but that's about it. It has always started up and ran. When you say it won't turn over do you mean the engine is seized or just won't fire up?
Posted: Sun Sep 09, 2007 1:16 pm
by diomike
wont fire up. i really dont now wat it is . its conpletly moded i got 70cc athena , 8-1 gear tecnic gas pipe ,28mm carb ,ct crome manifold , kili pully, 1500 center spring and the yellow clucth springs . alll that cool stuff by the way wat are u hiting i was hit around 60 65
i also have a question wat did u put to clog the oil pump hole???
Posted: Mon Sep 10, 2007 2:26 am
by jeremydde
diomike wrote:wont fire up. i really dont now wat it is . its conpletly moded i got 70cc athena , 8-1 gear tecnic gas pipe ,28mm carb ,ct crome manifold , kili pully, 1500 center spring and the yellow clucth springs . alll that cool stuff by the way wat are u hiting i was hit around 60 65
I didn't plug the stock oiler. I am still running it actually along with some premix as well. It was easier to do it this way then worry about removing it and grinding gears and what not. I just made a new throttle cable from the y joint and went straight into the carb. Keoni recommended I add an additional ounce of oil into every full tank of fuel. The engine is running very well. I am not sure about the top speed yet as I fall out of my powerband after 70km/h. My center spring is worn out, and Keoni forgot to put them in the box on my last shipment. They should arrive soon though.
Does your scooter smell really rich when you try to start it up? I had a tecnigas muffler before the phongeer and the silencer got plugged up before. You may want to check and see if your muffler is actually flowing. If there is not enough flow then there can't be flow through the carb and then you can't start it.
Spark plug wire
Posted: Mon Sep 10, 2007 2:29 am
by jeremydde
Also check your spark plug wire to see if it is damaged. Mine completely vibrated apart a few months ago and wouldn't start very well. I went to check the plug and the boot came off but the clip inside stayed on the spark plug.
Posted: Mon Sep 10, 2007 2:10 pm
by diomike
was it still making spark
Posted: Mon Sep 10, 2007 9:23 pm
by jeremydde
diomike wrote:was it still making spark
It was but it was weak.
Posted: Thu Dec 27, 2007 8:02 am
by 55bore
tru72 wrote:actually Dac you are incorrect about jogs. LOL as much as i hate to admit it, the jog/minarelli motor set up is way more efficient working than a dio motor "chokes" cough , cough! hahah I have seen this play out many times. I know that a 72cc set up built on both motors ,perfectly tuned, jog wins. Dio motors are more preferred in the states... other places around the world are more jog. I hate the sound of that...
I prefer my dio stuff, but if i could find a good jog in good condition, i would defiantly build that too! Its all your personal preference!
just have fun!
aloha
D
ps listen to veedub, he knows his jogs!
Interesting. This only sounds Sounds like A Jog beat A DIO. AFAIK, the fastest 72cc DIO in Honolulu hasn't lost to a Jog or a DIO (but it has beaten larger cc mopeds).
The Purple People eater is also like a nymphomaniac librarian - silent but violent, and s***, it sips gas too. And it's a DIO.
Clue me in, if I've missed something.
Posted: Thu Dec 27, 2007 6:36 pm
by darat
dont make me pull out the zuma lol
Posted: Thu Dec 27, 2007 6:50 pm
by Dac
the same way that the honda ruckus will never be as cool as the elite line...
the yamaha Zuma will never be as cool as the Jog line...
( its the hole New Vs. Old)( im a big fan of all 4 scooters. but how many parts can be bought really gives away the winner ( jog and dio) )
Posted: Thu Jan 03, 2008 3:30 am
by stillspeeding
I want that dumb * local boy, they all choke when they meet me
Posted: Thu Jan 03, 2008 5:41 am
by Dac
stillspeeding wrote:I want that dumb * local boy, they all choke when they meet me
what?
Posted: Sat Jan 05, 2008 9:59 am
by 55bore
Which dumb * local boy do you want?
Me?
I'm trying to share what I know, which isn't much.
Why would anyone "choke" when they meet you? Are you claiming to be Dave Toba who is in retirement but still the fastest in Hawaii? If you want to set up a race, then PM me to give myself an excuse to change my setup.
And no, I'm not Dave Toba, and my bike isn't tuned for racing right now, but I'll give you a run if you want it from me.
Who are you claiming to be able to beat in what kind of race with what size engine?
Posted: Sun Jan 06, 2008 3:07 pm
by darat
well thank god i got a minarelli on my zuma lol.
Posted: Sat Feb 23, 2008 1:08 pm
by veedubh20
55bore wrote:stillspeeding wrote:I want that dumb * local boy, they all choke when they meet me
Me?
he got record of 1/8 track only .
