Argh! Scooter won't start + father-in-law = Frustration
that sounds to me like a 'reed valve' problem.
do you have an air compressor? if so blow a non-stop stream of air right in the carb and try starting it.
for me when my reed valve went out. i unhooked my gas line and had the same problem you are having. my step dad tried this and it would run but if i let off the air it died. got a new reed valve and it worked perfect
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Did you check the compression?Anything with an engine that I squirted starter fluid in the carb started at least as long as the fluid burned-up as long as the compression was good and good spark.Also, after squirting fluid in carb. put hand over carb inlet partway to restrict some airflow so it is not too lean.If you have spark outside the engine then you should still have it when the plug is installed.Did you pull the muffler to see that it is clear and no carbon build up on the exhasut port?How about pulling the head to look for carbon?good luck
85' Aero
I don't know about the compression, but I did take the head off as well as check the exhaust for decent flow. You can feel air coming out of the exhaust while the engine is trying to start so I feel that is not the problem.joeweir1 wrote:Did you check the compression?Anything with an engine that I squirted starter fluid in the carb started at least as long as the fluid burned-up as long as the compression was good and good spark.Also, after squirting fluid in carb. put hand over carb inlet partway to restrict some airflow so it is not too lean.If you have spark outside the engine then you should still have it when the plug is installed.Did you pull the muffler to see that it is clear and no carbon build up on the exhasut port?How about pulling the head to look for carbon?good luck
When I first started working on the engine and I was cranking it via the kick start it would try to start for a short time.
I'll pursue the reed issue next.
OK, here's a dumb question - where is the "reed valve" and could it be called something else in the manual?GIJoeBob wrote:I don't know about the compression, but I did take the head off as well as check the exhaust for decent flow. You can feel air coming out of the exhaust while the engine is trying to start so I feel that is not the problem.joeweir1 wrote:Did you check the compression?Anything with an engine that I squirted starter fluid in the carb started at least as long as the fluid burned-up as long as the compression was good and good spark.Also, after squirting fluid in carb. put hand over carb inlet partway to restrict some airflow so it is not too lean.If you have spark outside the engine then you should still have it when the plug is installed.Did you pull the muffler to see that it is clear and no carbon build up on the exhasut port?How about pulling the head to look for carbon?good luck
Never mind - I found it. I was thinking it was part of the carb or cylinder but it is part of the crankcase.
I'll get the hang of this eventually.
I looked at the reeds and one of the two is just slightly not "seated". I bolted it back on and without putting the carb back on I cranked it and IT STARTED!!
I can spray a shot of starter fluid into the hole and it will start right up and run for a bit.
So, why won't it do that with the carb mounted?
I'm such an idiot. It did run out of gas. I just forgot to turn the switch to run after filling it up.GIJoeBob wrote:Well, I rode it around the block and it ran great for a few minutes, then started acting like it was running out of fuel and then died all together.
Now it is not getting spark. Ugh, I hate electrical problems.
It seems to be running well but the take off is a bit slow and it seems to bog down until it goes for a bit and then really gets moving.
I have a makeshift airfilter on it now that consists of a piece of large cell foam zip tied over the opening. I'll check the set screw as you suggest. The only one I can see is the one that adjusts the throttle cylinder. Is that the right one?hondaman wrote:Make sure your air filter is clean and set your air screw like I have stated in other posts. That may take care of the bogging problem.
The screw was it. It runs about 35 on level ground and accelerates like a scolded dog.GIJoeBob wrote:I have a makeshift airfilter on it now that consists of a piece of large cell foam zip tied over the opening. I'll check the set screw as you suggest. The only one I can see is the one that adjusts the throttle cylinder. Is that the right one?hondaman wrote:Make sure your air filter is clean and set your air screw like I have stated in other posts. That may take care of the bogging problem.
I had a small chattering noise coming from the gear box that turned out to be a missing circlip and the kick start return spring that was loose.
Now my only issue is the wheels. Both are bent. There is no vibration as you drive but I would like to correct this. Is there a way to repair this or am I stuck with buying new wheels?
dept of corrections
Just somthin i noticed on the prev pg. that didnt sound right to me
As the pic show, the starter relay gets its power from the IGN key and the BUTTON grounds the relay to make it work
coppied from the online manwell
Re: Argh! Scooter won't start + father-in-law = Frustration
I tried to start my Spree in the rain the other day, hit the electric starter and it stuck on. Sounds like my relay got wet / went bad. There was no way to turn it off without disconnecting the battery.
Is there still a source for reed valves for the NQ50's?
sj
sj
There is nothing wrong with your reeds. If the thing starts, the reeds are fine.cubdriver wrote:I tried to start my Spree in the rain the other day, hit the electric starter and it stuck on. Sounds like my relay got wet / went bad. There was no way to turn it off without disconnecting the battery.
sj
Oh and ignore DrZ34 because he doesn't really understand electrical systems. Yes, the key has to be on but the power for the start solenoid comes from the either brake switch, the start button supplies the ground to activate the start solenoid. If the key is in the off position and for some reason you did get the motor to crank, the engine will no start because the ignition is turned off.
