big screw up
No_Stopping_A_Spree
Post by No_Stopping_A_Spree »
I myself let my elite to idle at least 3 minutes before I take off for school in the morning..whether the temperature is 50 degrees Fahrenheit or 40..the colder it is though, the more time I give it to warm up
Dac
Post by Dac »
if you dont mind me asking were did you get your tack, it seems it would really help me.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
jeremydde
Post by jeremydde »
Dac wrote:if you dont mind me asking were did you get your tack, it seems it would really help me.
http://www.kosonorthamerica.com/
My honda dealer was able to get it but you should be able to order it online. The CHT probe kit was separate.
2000 Honda Dio
Malossi 72cc Bore
28mm Oko Carb 45 Pilot & 132 Main
Phongeer Long
9 to 1 Gears
Parmakit Variator
1500 RPM contra spring
Kuka Clutch w/Polini green springs
Koso Digital Tachometer w/CHT
Dac
Post by Dac »
whoa those are not cheap. only a few of those were cheaper then my bore kit . is there any not 200$ way of finding temperature?
stillspeeding
Post by stillspeeding »
For a temp guage go to vtcycles.com they were about $87 and why would you need a tach? it has no shift points, which is the only reason a tach is used for :lol: after you blow your first bore kit your temp guage will tell ya when to back off unless you :shock: change the gear ratio
Can't afford speed then stay away from it!
stillspeeding
Bmx, i would love to run your japan dio with the wrong gear ratio with my u.s. version dio and smoke your * :o and keep the tach incase you have shift gears :roll:
jeremydde
Post by jeremydde »
stillspeeding wrote:Bmx, i would love to run your japan dio with the wrong gear ratio with my u.s. version dio and smoke your * :o and keep the tach incase you have shift gears :roll:
Actually the tach was quite useful. As I accelerate I can see what rpm my powerband kicks in and then I can tune my weights and springs to let the bike accelerate in it's powerband constantly. So technically there is shifting to tune. And then I have to retune again everytime I change something, or when parts wear out.
2000 Honda Dio
Malossi 72cc Bore
Phongeer Long
9 to 1 Gears
Parmakit Variator
stillspeeding
If you can't change the gear ratio expect to blow your bore kit! but you can buy a cheap elite-s 94 & up from the Michigan boys cuz they don't know how much they are worth :lol:
Dac
Post by Dac »
now is this true or are you full of s***? i know many people who have bore kits on there 93-under elites that work fine. my newest one is still going good.
and 'michigan boys' are not as stupid as you think other wise i would be riding a 94+
stillspeeding
It takes $bucks$ to build & own a full stroker & balls to ride one :D
Dac
Post by Dac »
i got the balls to ride one. i use to ride a 150cc scooter allot no problem. i know a stroker has tons more power but i think ill be good.
only down side being money. im 'low' (aka OUT) of money at this point. with my low * income im happy to afford my elite.
burnt_toast
Post by burnt_toast »
its all good man, these things happen. just a lesson that taking time to tune is very important. make sure to run richer next time, check intake system for leaks and use a good filter.
projects galore :nerd:
burnt_toast
correct, I have a koso multi tach that I have used to tune my zip stroker. It was very handy till it stopped working. Even though cvt's are "automatic" they do shift and monitoring at which engine speed they do this at can really help you tune.
my tach/temp gauge:
Dac
Post by Dac »
is my Uni Pod filter a good filter?
its always worked great and i oiled it to help the filter out dust and what not.
I love Ventos, i wish i could get one. my friend got a 04 Zip for 400$ from a guy who had 2 of them, the guy wanted 500 for the other one. i went to buy it the next day and it was already sold.
about how fast do your 2 ventos go?
burnt_toast
filter looks fine as long as you upjetted the stock carb, would guess you'd need atleast 85 main but a bigger carb would really help w/ 70kit.
Got the 90cc Zip stroker to do 64.5mph by gps, not fully pushing it. Completely custom intake, setup for acceleration with stock straight cut gears for max torque.
Triton at 70cc and stock upjetted carb, got 69.4mph gps.
Italjet is due for a gps run, and the Elite is sitting at a cool 0mph :lol:
