wire tie-ing the oiler open
stillspeeding
the main reason for having it wide open is to make sure its getting oil on the off throttle position. Think about this, it only opens when you are on the gas, so what happens if your coasting down along hill. We al know that the bike wil now go back to idle until you slow down. Now its spinning there, you guessed it, with very little oil. Adding a few cap fuls of oil in your gas is good idea too.
To me more oil is better than no oil..
aloha
D
aloha
D
I was thinking about that the other day while going down a long down hill, so I gave it a bit of gas. If you have the adjustable oiler you can adjust it so that at the smallest throttle opening it is adding oil. Or just wire it open and clean your plug often. Harbor freight sells a plug cleaner for $16.
88 elite SA50
07 DRZ436sm
05 FJR1300a
05 Dr200se
07 DRZ436sm
05 FJR1300a
05 Dr200se
still speeding, id like you to see something. your retarded. look at the top poster on the site.... o wait, ha, its me! now i have not heard ONE bit of real true help from you. and i believe that if you keep on with your bs, i will just ban your ip address. now i will say that sprees have ONE cable, they have NO adjustment on there oiler, and if you follow the cable under your floor board. there will be were the lines split. take the whole oiler cable off. i have my tied all the way open at all times, and run just fine. even when it was 50cc i had it open all the way.
one time he told a dude that a 94+ elite is better then a 89 elite. that was the only time he was ever usefulstill speeding, id like you to see something. your retarded. look at the top poster on the site.... o wait, ha, its me! now i have not heard ONE bit of real true help from you.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
