rebuildin 1987 honda elite need help.
myhonda
Post by myhonda »
still trying to figure out y i have no take off.
Post by Kenny_McCormic »
Clutch needs rebuild? Maybe your belt slips?
Dac
Post by Dac »
try taking off your air filter once....
[every one calm down, i know running with out an air filter is bad but its just to check.]
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
myhonda
Post by myhonda »
with the air filter off it just bogs out and dies. with it on the way it is now if i give it full throtal it starts to SLOWLY take off and starts rolling for like 2-4 sec then it starts to take off. i have to help it by foot to get it to move on hills from a stop.
Have you tried setting the carb richer?
myhonda
Post by myhonda »
yes i did as instructed befor and set hte clip down a notch to make it not run lean.
55bore
Post by 55bore »
Just to check:
1) Are you running old gas? Burn some weeds with it.
2) How is your idle?
3) Does it rev nice on a stand?
myhonda
Post by myhonda »
i had sat for a year with no gas in it i drained it out fresh gas inside the tank carb is clean. it idles fine for the most part if i leave it there for a few min it stalls out it revs up on the stand.
myhonda
Post by myhonda »
would not having a battery in it cause this effect?
I doubt it but even if the batt is dead you should have one in it.
myhonda
Post by myhonda »
well with a battery on thyere made no difference. she's still got crap for accell from a stop.
55bore
Post by 55bore »
myhonda wrote:if my drive belt is a little too big will it effect takeoff? not big like longer but slightly wider
Yes, it's going to make both your take-off and your top speed worse.
myhonda
Post by myhonda »
ok so problem found. will the belt wear in or will i need a new one? if new belt needed what size is needed ?
uspmale
Post by uspmale »
Honda has them.
I've got a dozen belts for Spree's, but not for Elite.
If this fails, check compression and main jet size.
