ShochuJohn
Posts: 22 Joined: Fri Dec 28, 2007 12:31 pm
Post
by ShochuJohn » Sun Apr 13, 2008 7:14 pm
As an addendum, I attempted to use vise grips as well as pliers. It's just pressed in there right? Not screwed?
chevyguyjay
Posts: 1167 Joined: Sat Feb 03, 2007 5:09 pm
Post
by chevyguyjay » Sun Apr 13, 2008 7:16 pm
vic grips always work best. u dont wanna crush it, but u do want a good bite on it. then......without pullin your shoulder out of socket.....pull it out.
~2004 Geely Fashion~
ShochuJohn
Post
by ShochuJohn » Sun Apr 13, 2008 7:38 pm
Allright, I got it out. I see a pinprick of light coming through it, smaller than the opening on either end. I pushed a paperclip into it and it seems pretty solid. Is this a blockage or how it was manufactuerd?
The body of the carb above this needle it also features a pinprick hole.
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Sun Apr 13, 2008 8:58 pm
The idle jet should only pass a pinprick of light.
berreta22
Posts: 508 Joined: Wed Mar 22, 2006 2:04 pm
Post
by berreta22 » Sun Apr 13, 2008 9:24 pm
Your rings are blown..i blew mine up 3 times in a month before i found the oil pump to be the culprit.
ShochuJohn
Post
by ShochuJohn » Sun Apr 13, 2008 9:50 pm
How's this for an alternative theory. I noticed that my tinkering seemed to be producing a puddle by the back wheel. Black, but not as thick as oil, perhaps some sort of oil/gas mix. It seemed to be coming from inside the crankcase, so I pulled the crankcase cover off. It's hard to see, but I think it is coming around the drive pulley.
Does this add any clues?
Post
by Kenny_McCormic » Sun Apr 13, 2008 10:19 pm
You blew a crank seal.
ShochuJohn
Post
by ShochuJohn » Sun Apr 13, 2008 10:28 pm
Well, at least I know what the problem is. How much of the block do I have to tear down to replace it?
Post
by Kenny_McCormic » Sun Apr 13, 2008 10:30 pm
ShochuJohn wrote: Well, at least I know what the problem is. How much of the block do I have to tear down to replace it?
Full teardown and internal cleaning/inspection.
