Page 2 of 2
Posted: Sun Apr 27, 2008 3:14 pm
by rpm9001
pulled apart carb, Main jet clogged solid. Cleaning now.
Thanks!
Posted: Sun Apr 27, 2008 5:22 pm
by Gamemedic
Make sure your air box is on with a filter in it or it will not run right. Also the voltage to the bystarter is AC not DC, set your meter.
Posted: Mon Apr 28, 2008 4:42 pm
by justinnielsen01
clean your carb out before you put your new air filter in so it dosent mess up the carb
Posted: Mon Apr 28, 2008 7:15 pm
by Kenny_McCormic
justinnielsen01 wrote:clean your carb out before you put your new air filter in so it dosent mess up the carb
WHAT???
Posted: Mon Apr 28, 2008 7:49 pm
by hondaman
Once again its a dirty main jet. 99% of the time the answer is CLEAN THE CARB! Do yourself a favor and put an inline gas filter on. It helps stop the dirt the filter in the gas tank does not catch.
Posted: Tue Apr 29, 2008 3:07 pm
by rpm9001
I added the filter before I even cleaned the carb. Thanks!
