What is your top MPH?
keithw
Post by keithw »
Add modified varator to the list and bump speed up to 45.
Honda Spree, 1985.
Another Honda Pal
Post by Kenny_McCormic »
evilone wrote:Kenny, where in southern Michigan do you live?
About 10 mins from jackson.
chevyguyjay
Post by chevyguyjay »
ok, i weigh 230lbs. i have the mods done to my 86 aero50. stock piston, cylinder has been ported and polished, the muffler has been cut opened and had stock pipes replaced with bigger pipes, it has a shaved 85 spree head with the plug gapped at .036, advanced timing, ram-air fin on the fan cover, it has a 95 sa50 carb with a 90 main jet, and a aftermarket K&N filter, it has the 87 SE50S shiftkit with three 9 gram rollers, and three 10.5 rollers. since i did the new upper end with a new piston and rings, it will do 44mph flat. im good with that. :wink:
~2004 Geely Fashion~
danmdevries
Post by danmdevries »
04 Kymco ZX50
I'm 6'3" 250lbs
Stock gearing: 45mph flat, 51 downhill.
2004 Kymco ZX50
70cc kit, 19mm carb, chambered exhaust
THE 72
Post by THE 72 »
sym dd50 72 7:1 gears 68mph with headwind
GIJoeBob
Post by GIJoeBob »
GIJoeBob wrote:1985 stock Spree - 30mph
1987 stock Elite 50s - 38mph
The Elite now is doing about 42mph with the nose and panels on.
mopedman
Post by mopedman »
45 mph with my new r1 and pulley kit
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
jxnslotcar
Post by jxnslotcar »
I weigh around 195 and on my stock 86 spree i have it up to 32 mph on level ground-don't know that I want much more than that. If I want to go faster,I can jump on my chopper or another motorcycle. I like cruising around the area on a Spree. I now have 3 of them. I am going to sell one of them. The other 86 I am going to 87 plastics as I like the look more.
2 OR 4 WHEELS,IT'S ALL GOOD!
nparks
Post by nparks »
~60mph... then the engine seized. =(
justinnielsen01
Post by justinnielsen01 »
about 55 on a elite dio. high speed pully, 9:1 gears, nechnigas pipe next r and 72 main
DorkoElite303
Post by DorkoElite303 »
nparks wrote:~60mph... then the engine seized. =(
OMG...Didn't you just start building your set-up? And you already got a engine seized?? Did you even break it in???
Did you try freeing it with PB like I told you?
Dac
Post by Dac »
kinda useless when there is a hole in your piston....
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
nparks
Post by nparks »
Obviously not good enough. I put just under 100 miles on it and decided to see what it'd top out at and as soon as I hit 60 it popped.
nparks
Post by nparks »
Haha yeah I did, but it was nearly impossible. It definitely helped though! Without PB I'd still be clueless as to how I'd get the d*** piston off of the crank.
