Page 2 of 3
Posted: Thu Jul 17, 2008 5:38 am
by maddog
you dial in the trans according to your riding style and your weight, if you go lite on the trans you will not have to change certain parts all the time.
Posted: Thu Jul 17, 2008 8:42 am
by MIKEBB
Where do you get 4k clutch spring and how much?
Posted: Thu Jul 17, 2008 9:45 am
by Karman
MIKEBB wrote:Where do you get 4k clutch spring and how much?
VT Cycles. I think they're $16. Tell Keoni you want yellow clutch springs (4,000 rpm). They'll make a scoot with some power into a neck snapper. They basically skip the lower part of the power band and just rev through it. Keep in mind - they're a MAJOR pita to install because they're so tight.
Posted: Thu Jul 17, 2008 10:12 am
by MIKEBB
Karman
what is your set up and what is your top speed?
Posted: Thu Jul 17, 2008 10:18 am
by MIKEBB
oopss. What I meant is, do you have 4k spring now? I have 1500 rpm.
Posted: Thu Jul 17, 2008 5:08 pm
by Karman
MIKEBB wrote:oopss. What I meant is, do you have 4k spring now? I have 1500 rpm.
You might be getting the clutch springs (there are 3) confused with the compression spring. I installed the 4,000 rpm clutch springs and a 1,500 compression spring at the same time. I didn't like the clutch springs (no low speed throttle) so I went back to stock but kept the 1,500 compression spring.
Posted: Fri Jul 18, 2008 8:30 am
by MIKEBB
I'll try that set up. Hopefully I have a better take off. Did you also change the jet in the carb?
Posted: Fri Jul 18, 2008 1:14 pm
by Karman
No - there's no need to rejet. You're just changing the take-off and tweaking when the clutch engages by swapping out the springs. The part of the powerband that is usually slow with stock springs is just skipped (you rev through it) with the stiffer springs.
Posted: Sat Jul 19, 2008 1:37 pm
by PimpinSpree
how fast do you think i could go with a contessa big bore and 8.4:1 gears?
Posted: Sat Jul 19, 2008 1:42 pm
by Kenny_McCormic
PimpinSpree wrote:how fast do you think i could go with a contessa big bore and 8.4:1 gears?
with a high speed pully and some tuning you will be in the 60s, MAYBE low 70s.
Posted: Mon Jul 21, 2008 1:42 am
by PimpinSpree
how about with 9.1:1? i want to get my se50 spree to cruise easily at 50
Posted: Mon Jul 21, 2008 2:40 am
by Kenny_McCormic
You could cruise at 50 no problem, cruise is well below top speed. With 9s you would just be making more noise and wasting gas.
Posted: Mon Jul 21, 2008 10:03 am
by PimpinSpree
well i don't care about my top speed being around 50, i probably won't even go that fast, i just want the option. I'll do most of my driving at 35 or so. So anyone know how fast 9.1 gears get you on a bored scooter?
Posted: Mon Jul 21, 2008 12:31 pm
by Kenny_McCormic
PimpinSpree wrote:well i don't care about my top speed being around 50, i probably won't even go that fast, i just want the option. I'll do most of my driving at 35 or so. So anyone know how fast 9.1 gears get you on a bored scooter?
You shouldnt run them because they will wear out the bore quicker. Lower gearing=higher RPM for same speed.
Posted: Mon Jul 21, 2008 3:40 pm
by cf_z
well i got them today.
he got my 8.4 prefference in before he shipped.
does anyone know what 8.4 can cruise easily at without stressing the motor? (corsa)
