Page 2 of 2
Posted: Sat Jul 19, 2008 11:17 pm
by justinnielsen01
Dac wrote:contessa is longer lasting.
and still has more power then most other 72cc bore kits.
there is a contessa on ebay brand new for 230 with shipping is that a good deal. and what size carb would i need? how many miles do you have to break them in for?
Posted: Sat Jul 19, 2008 11:45 pm
by happyman
Kenny_McCormic wrote:happyman wrote:i have a couple of motors running the westach temp gauges i know i am jetted rich, the the motor heads over 350 very fast for whatever reson. i think the sensor is not good.. i have just the part that goes over the plug for a spre and i will change it out one day soon.. ya never know how far off these things are,, Keoni says they can be off quite a bit. i would like something i could trust for actual temp.. i have one also on the smaller buiold and its a much more steady reading. i think like 20% off, and at 350 that is a lot.mine will cross 400 very easy and i have looked in the exhaust port andits looking good. a nd side to side and shows no blow by on the rings. still runs very good so i think if the guage was right it would show up as scuffing at least. still bothers me to see the temp go up like that. and so easy on just mild running at say 40 to 45 mph
burnt_toast wrote:300-350F op temp on Corsa, contessa should be similar if not slightly cooler
westach temp sensor is best, made for small aircraft and reeds up to 600+F and has sparkplug sender reader
Try a richer pilot.
wow, i think the next size is a 52, run a 50 now. guess can try it again. had it in for a few hunderd miles, seemed pretty rich and never seemed to run cooler but its not a big job to try it again.
Posted: Sun Jul 20, 2008 12:12 am
by justinnielsen01
never mind
