Ahhhh very nice i will do that. i dont want to mess up anything
i love to hop off curbs lands nice but i dont want to break anything
thanks
Heavy Duty Rear Spring for Spree??
Re: Heavy Duty Rear Spring for Spree??
Re: use a cb750 shock
I would like to see a picture of this!Videonut wrote:ok it is a slight mod but i used a honda cb750 rear sprin on my spree. it lifted it about 4-5inches and i had to remove the airbox and make a mount for it but it rides so nice and i can jump off curbs. i also put a killer set of knobbys on it looks killer
I am very interested in this.Videonut wrote:ok it is a slight mod but i used a honda cb750 rear sprin on my spree. it lifted it about 4-5inches and i had to remove the airbox and make a mount for it but it rides so nice and i can jump off curbs. i also put a killer set of knobbys on it looks killer
Could you explain this in detail?
here ya go guys it works goood but i dont want to break anything... i dont think i will im not a heavy guy and the spring is progressive but if you look at it close the mount i made has broken on one side yikes i have to fix it
videonut
So any of those 'performance' shocks, with the adjustable preload for an elite should work then? correct?
well with a little mcgivering any shock will work.
thats my oppinion
thats my oppinion
But without any mod.
I believe KMcC said that an elite shock will fit a spree. so a performance elite shock, should as well fit a spree.
I know a SB50 is drop in and gives a couple inches.
Those performance shocks are often wider (or the adjustment collar on the bottom stick out) and they really hinder tire clearance. All my friends with aftermarket shocks have grooved tires.
