Page 2 of 2
Re: Heavy Duty Rear Spring for Spree??
Posted: Thu May 28, 2009 2:12 am
by Videonut
Ahhhh very nice i will do that. i dont want to mess up anything
i love to hop off curbs lands nice but i dont want to break anything
thanks
Re: use a cb750 shock
Posted: Fri May 29, 2009 12:29 am
by GIJoeBob
Videonut wrote:ok it is a slight mod but i used a honda cb750 rear sprin on my spree. it lifted it about 4-5inches and i had to remove the airbox and make a mount for it but it rides so nice and i can jump off curbs. i also put a killer set of knobbys on it looks killer
I would like to see a picture of this!
Posted: Tue Jun 09, 2009 10:41 am
by GIJoeBob
I am very interested in this.
Could you explain this in detail?
Posted: Wed Jun 10, 2009 10:34 pm
by Videonut
here ya go guys it works goood but i dont want to break anything... i dont think i will im not a heavy guy and the spring is progressive but if you look at it close the mount i made has broken on one side yikes i have to fix it
videonut
Posted: Wed Jun 10, 2009 10:54 pm
by toboggan
So any of those 'performance' shocks, with the adjustable preload for an elite should work then? correct?
Posted: Fri Jun 12, 2009 12:26 am
by Videonut
well with a little mcgivering any shock will work.
thats my oppinion
Posted: Fri Jun 12, 2009 12:29 am
by toboggan
But without any mod.
I believe KMcC said that an elite shock will fit a spree. so a performance elite shock, should as well fit a spree.
Posted: Fri Jun 12, 2009 3:48 pm
by Kenny_McCormic
I know a SB50 is drop in and gives a couple inches.
Posted: Fri Jun 12, 2009 3:57 pm
by 808BMW
Those performance shocks are often wider (or the adjustment collar on the bottom stick out) and they really hinder tire clearance. All my friends with aftermarket shocks have grooved tires.
