Posted: Thu Oct 16, 2008 6:27 pm
Because high pressure air can and will blow out pressed in restictors and such and you will loose them. Some manufactures will even caution you about high pressure air.Kenny_McCormic wrote:Why?Bear45-70 wrote:High pressure compressed air for carb cleaning is a no-no. Nothing more than about 35 PSI. That's why a carb cleaner spray can, brake clean or WD-40 is better than compressed air. If you insist on blowing it out after words, they make cans of just compressed air for than.greenninja37 wrote:any other ideas? or should i just clean the carb extremely well and used compressed air this time? or any ideas for other problems?
