Restoring a 1988 Spree
I've finished the clean and blow out of the carb, however when its still over oiling the plug. I have wound the air screw all the way out in order to lean it out, but still no joy
Not one day that we are here on this earth is promised to us, so treat every day as if it is your last, and every breath as if it were the same
198? Honda Spree NQ50M (got parts of two different bike mixed up in there!)
There lies the problem. Try holding you hand over the intake holes while cranking, replace the spark plug(they might look and function fine but under compression is a different story).
I'll definitly try that thanks.
I did buy a hotter spark plug in order to get a cleaner burn, but the spark lead wont fit the new plug:(
I my have been led down the garden path by the parts dealer- I went to get a NGK BPR6HS as per the downloaded service manual, but all he had in stock was a BPR4HS. The current plug in the head is a BP5HS
Should be a BPR6HSA for normal riding.Storm wrote:I my have been led down the garden path by the parts dealer- I went to get a NGK BPR6HS as per the downloaded service manual, but all he had in stock was a BPR4HS. The current plug in the head is a BP5HS
And a BPR4HSA for cold weather below 5°C or 41°F.
Or a BPR8HSA for extended high speed riding.
What is top speed for a Spree really be considered "high speed"?
WOT down back roads for miles at a time.Bear45-70 wrote:Should be a BPR6HSA for normal riding.Storm wrote:I my have been led down the garden path by the parts dealer- I went to get a NGK BPR6HS as per the downloaded service manual, but all he had in stock was a BPR4HS. The current plug in the head is a BP5HS
What I meant was, "Can 30mph + or - i or 2 mph real HIGH SPEED." *, where I live the lowest speed limit is 30mph.Kenny_McCormic wrote:WOT down back roads for miles at a time.Bear45-70 wrote:Should be a BPR6HSA for normal riding.Storm wrote:I my have been led down the garden path by the parts dealer- I went to get a NGK BPR6HS as per the downloaded service manual, but all he had in stock was a BPR4HS. The current plug in the head is a BP5HS
*, I have a 250cc 4 stroke full size quad weighing 500+ pounds not counting me and it will do 48 mph on the GPS.Kenny_McCormic wrote:Considering its the highest the poor little bike can go, yes its high speed.
