Spree starter motor compression
Hmm. If it's wiggling I'm wondering how much of the wires connecting it to the brush are still intact.
When you had the motor apart did you clean the commutator? A few bad spots on one will cause the condition you are having.roadcapDen wrote:Hey Noiseguy, yes I've had the motor apart and everything looks/smells good, lots of wear still left on the brushes, turne freely, bike only has 2,000 km on it, even had an alternator shop look at it.
I have never took a starter motor for one of these apart, but when it was apart would you be able to take the armature and put it in a drill chuck, then get a piece of emery cloth and wrap it half way over the commutator while spinning it in a drill.
roadcapDen
- Goped
roadcapDen
- Goped
A typical 10A charger won't (by itself) provide enough current to start the bike.
roadcapDen
- Goped
That would be my guess. Try using some 12 ga wire to jumper past the existing harness; you can find the weak link that way.
DENMANSHAFFER
- Goped
STARTER MOTOR
Be careful when reassembling a starter motor from a Spree. They can easily be put together one third revolution off, the bolt pattern allows that, and the starter will work, but will spin backwards.
I believe the normal rotation is counter clockwise which drives the starter gear clockwise. the motor runs clockwise.
roadcapDen
- Goped
roadcapDen
- Goped
Again, if you lessen the load, loosening the spark pug does that by lowering the compression, it makes it easier for the weak starter to do the job. Repace it and you should be golden.roadcapDen wrote:Connected the starter to the + terminal of battery with starter installed on bike (12ga) and it's doing the same thing???
Loosened spark plug 1/8th turn and starter works fine???
I'm stumped,,,again???
roadcapDen
- Goped
Thanks for the replys, the crankcase is OK.
The starter when hooked up to the battery directly and off of the engine spins so hard and fast that it gave me a blister thru my leather gloves while trying to hold the gear on the end of the shaft, so that makes me think the starter has lots of tourqe and should be good! No??
Not necessarily. Put the starter back in and try starting it by running the motor directly off the battery like you're testing it now. If it can easily turn over the motor, it would indicate wiring problems.
Just out of curiousity, have you pulled the head and looking inside the jug to check condition of the head, walls, and exhaust port?
roadcapDen
- Goped
Thanks, it will easily turn over the engine but only with the spark plug a little loose, like not quite hand tight, otherwise when tight it won't turn over a full revolution.
Doesn't seem to be a difference with wires hooked up directly to battery or normaly.
I've had the top end apart, all is clean and piston moves freely and same with the exhaust off, port is clean.
