ram air
To hit 100mph with 9:1 gears the engine would need to be spinning around 16,000 RPM, something I HIGHLY doubt his piece of s*** motor can crank(assuming it has actually ran at one point or another).
- SpyderMike
- EliteS120ccJDM
we have been waiting for 2 months now....EliteS120ccJDM wrote:52.6mm crank and 54mm bore...f*** you guys..wait till i put the vid up..
Should i even mention here about how you posted on the hawaii forums, and there was over 3 pages of people talking bad about you?
Post up the video and prove all of us wrong.
Until then, stop lying, because we know you are lying.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
What he said.Dac wrote:we have been waiting for 2 months now....EliteS120ccJDM wrote:52.6mm crank and 54mm bore...f*** you guys..wait till i put the vid up..
- EliteS120ccJDM
Ok 1st of all..the 70cc kit was an aluminum mhr kit...2nd of all my block was taken to the machine shop..yes it was milled down..and yes I did mill the crank a little bit..like 1 or 1 nd a half mm...3rd of all..I guess this * * idea aint goina werk..so that's off the list..does look kool though...but I'm jus waiting on my piston..wen it does arrive and I have time to put this bike together I'm going to take it out ont he highway and prove u all wrong..also..my carb is rejetted to 185 , and I ported the cylinder..ported the reed entrence on the motor..and it has a ported high compresion head..yes my block is milled down!!
you seized your motor?
you dont say...
i did just say that a mod such as this would lead to a motor seize and... Whats this???? IT DID???? ... wow...
Lets follow along with your story for a second and see if this makes any since...
Your Bike had to much compression so the kick start gears started to get wore out. Instead of fixing the gears you took the bottom ring off. Once your gears did go out, you had to order more so you could start it and prove to us that we are all wrong.
But then you got in your gears in. We all waited about a month for you to post this video and you never did. Now that we ask about it you admit that you destroyed your piston (what a surprise). So now your waiting for your new piston to come in. Then once you get your new piston in you are going to put your bike together with your new "ported high compression" head.
Can i go ahead and guess the next part of this story?
some story about broken kick start gears, or something about you taking out the rings. I mean, you did it before.
you dont say...
dont you think on a 120cc set up you have enough compression?.and it has a ported high compresion head.
- burnt_toast
that ram air adds +20hp to the WHEEL at least! plus gets him mad street cred for sure
roll by a civic and flash him a piece of that blue ram air tubing and it'll put their cold air intake to shame!
mad props, cap it off with a cone filter for that genuine CAI look and no telling the awards it would win OMGZ fo real
projects galore
- EliteS120ccJDM
- burnt_toast
you're talking about that there baller ring, again a symbol of mad street cred. cant ride widout it homie. throw it back on and get in da game!EliteS120ccJDM wrote:It wasn't kus of the ram air...if u look closly at the piks it dosent have the cylinder on...I put the ram air after it got messed up because I forgot to take the little ring of that goes under the bottom 1..I'm not to sure of its name..
projects galore
- EliteS120ccJDM
burnt_toast wrote:that ram air adds +20hp to the WHEEL at least! plus gets him mad street cred for sure
roll by a civic and flash him a piece of that blue ram air tubing and it'll put their cold air intake to shame!![]()
Lmao!!!hahahahhahahahahahahahahahhahahahahahahhahahahahahahhaha..I'm like lauphin hard as * over here..lol..hahahhaha
- EliteS120ccJDM
burnt_toast wrote:you're talking about that there baller ring, again a symbol of mad street cred. cant ride widout it homie. throw it back on and get in da game!EliteS120ccJDM wrote:It wasn't kus of the ram air...if u look closly at the piks it dosent have the cylinder on...I put the ram air after it got messed up because I forgot to take the little ring of that goes under the bottom 1..I'm not to sure of its name..
Lmao!!hahahahahah baller ring..lmao hahahaha
- EliteS120ccJDM
- EliteS120ccJDM
