Page 2 of 2
Posted: Mon Apr 06, 2009 4:50 pm
by bradthreee
Here is a link to his original post:
http://hondaspree.net/phpBB2/viewtopic.php?t=8797
AF28 engine code....
Posted: Mon Apr 06, 2009 6:27 pm
by sanjuro
bradthreee wrote:After reviewing Sanjuro's post the carb is the Japanese model dio so it should be bigger. Hopefully it will bolt onto the stock intake mani if not then I may possibly need to get the JDM mani as well, if it even fits into the SE50 engine. I guess I'll just have to see :oops:
The JDM intake manifold on the Dio ZX models are available from online parts dealers like ronayers.com and hondaparts-direct.com.
The part number for the JDM Dio ZX part is: 17101-gw0-000
I looked up the 2001 Elite intake manifold and it uses a different part number: 17100-GZ5-010. They look the same to me though so you shouldn't have a problem.
BTW, the '87 Elite has the part number: 17100-GR1-670. It looks quite different compared to the AF28 and SA50 intake inlets.
Posted: Mon Apr 06, 2009 11:39 pm
by bakaracer
The base on the intake manifold it curved on the 87 and straight on the dio.you can use the dio manifold on the 87 but not the 87 1 on the dio.the 87 manifold is better than the dio because the opening is just a little bigger and its shorter to the reed block.
Posted: Fri Apr 10, 2009 5:46 pm
by bradthreee
bakaracer wrote:The base on the intake manifold it curved on the 87 and straight on the dio.you can use the dio manifold on the 87 but not the 87 1 on the dio.the 87 manifold is better than the dio because the opening is just a little bigger and its shorter to the reed block.
The Dio carb doesn't fit on the SE50 mani. It seems that the holes for the mounting bolts are a bit too short
I just put in a new plug and thoroughly cleaned the carb again and blew it out with compressed air.
I put the stock exhaust with washer and it raised the compression a bit.
Still not starting :x
Help!!! :shock:
Posted: Fri Apr 10, 2009 11:03 pm
by bradthreee
I took the piston off and one of the rings was stuck :shock:
I ordered gaskets from the dealer as well as received a used piston/ cylinder from wheelman and hopefully that will fix the problem.
Keep you guys posted...
Posted: Thu Apr 16, 2009 5:30 pm
by bradthreee
Gaskets came in. I need to go pick them up. I'm excited but I wont get to work on it till next weekend :cry:
