Flinthills axt:
Depends what "it" is. Going from 28 to 37 MPH is a laudable goal. Keeps you from being food-processed through the grill of a Silverado.Thanks fellas. So basically, swapping out gears, new pulleys won't do it then?
There's value in building out whatcha got. Lots more to be learned doing it yourself than from bolting in someone else's idea of "Performance." Parts are cheap and available. If you trash it, no big deal. I've found the process slow but rewarding.I would need to swap out the engine?
Then when you're ready to build that Dio, you won't make the rookie mistakes on pricier parts.
