Page 2 of 2
Dies on bumps
Posted: Sun May 03, 2009 1:42 am
by mahall665
How do you check float height? The manual is a little brief.
I've checked and wiggled every wire I could get my hands on and found nothing. It has to be gas related. I checked bouancy on the float..it defintely floats and doesn't leak anything inside. Being all plastic, I would think it's not adjustable?
It HAS To Be Gas-Related
Posted: Sun May 03, 2009 9:48 am
You are correct in that the float is non-adjustable. Honda-san's prescribed remedy for an out-of-spec float is to buy a new one.
I'm not convinced yet. Maybe it's in one of the wires you didn't/couldn't get hands on? There's some stuff behind the front cover and right side plastic too.
The carbs on these things are not very impact sensitive, unless it's a loose/stripped mounting. If you can reproduce the kill by * the carb, that may be it. The carb flange threads are prone to stripping if abused. Otherwise, I'd still rule out electrical. These intermittent faults are a leading cause of male-pattern baldness.
No bump-related float malfunctions have been reported before, AFAIK. If you mount a known-good carb from another bike and the symptom's unchanged, you will have your answer quickly.
Posted: Tue May 05, 2009 2:06 am
by Clivester
You generally check a float by placing it in warm-hot water and looking carefully for air bubbles forming on the surface of the plastic. Any bubbles appearing form nowhere indicate a leak. Don't use really hot water though - you may pop it!
Clive.
Update?
Posted: Wed May 06, 2009 12:21 pm
So?
Posted: Fri May 15, 2009 5:51 pm
by Garretts_turbo
same thing happened to me yesterday. its raining right now or i would look into it but yeah, going down the road i hit a bump and it sputtered and died on me and wouldnt restart.
gas and oil were topped off, i doubt its a gas delivery problem.
i'll post when i get a minute or two to work on 'er.
Posted: Fri May 15, 2009 6:04 pm
by teeoce
Make sure that the plug cap is secure on the spark plug.
Posted: Fri May 15, 2009 11:43 pm
by tazland001
it is a short somewhere. I have seen scooters do that. check the coil and cdi connections, also check you stator connections. . You are grounding out somewhere. double check your ignition wires also.
marc
Posted: Tue May 19, 2009 11:10 pm
by Garretts_turbo
well i finally had a chance to check out what my issue was; the spark plug had backed itself out of the cylinder, as well as the positive side ignition wire worked itself loose. fixed both and ta-da! ran again no problem.
as an aside, this is the second time in the few weeks i have owned it that the plug has backed itself out of the hole....once i get a new plug i'll have to loc-tite it in there.
Re: Dies on bumps
Posted: Wed Aug 05, 2009 4:34 pm
by mahall665
Well, after putting a new needle and float in the carb, the thing still continues to die if you * it or bounce it. Anymore suggestions? I guess I'll keep checking the electrical.
Re: Dies on bumps
Posted: Thu Aug 06, 2009 4:27 pm
by Lunytune
Something's wrong if you have the plug backing out. You shouldn't have to use loc-tite, and in fact I would be fearful to use loc-tite. I suggest maybe you're not torquing the plug down enough.
I'd still (not?) rule out electrical. These intermittent faults are a leading cause of male-pattern baldness.
One of these days, Wheelman is going to honor us with a photo of that bald knob. :mrgreen: I'm with the ole baldy on this one. Although, there might be a vacuum line that is wiggling on bumps just enough to kill you. It's a long shot, but check for old and cracked vacuum line. Then go back to checking electrical.
Re: Dies on bumps
Posted: Thu Aug 06, 2009 4:55 pm
Something's wrong if you have the plug backing out. You shouldn't have to use loc-tite, and in fact I would be fearful to use loc-tite. I suggest maybe you're not torquing the plug down enough......
Be careful about torquing a steel spark plug in an aluminum head. The threads will strip out of the head if you get ham handed. Use a torque wrench when in doubt but the torque setting for an aluminum head is 15 foot/pounds max. I would suspect that a plug that keeps coming loose has a over crushed washer. FYI, Loctite on a spark plug is a no-no.
Re: Dies on bumps
Posted: Sat Oct 03, 2009 12:26 pm
by redrocket
hey i have read alot about this ppl saying the fuel or electrical my spree used to do it to well i replaced the carb and it does it no more huh im sure every scooter is different but that fixed mine
Re: Dies on bumps
Posted: Sun Oct 04, 2009 10:00 am
by bradmeehan
There was a thread a while back called "Bumps cause Spreeicide" or something like that. You might find more info there as well.
Re: Dies on bumps
Posted: Mon Oct 05, 2009 8:02 pm
by redrocket
did you play with the bystarter at all make sure it is working right i think that may have spmething to do with it if its not electrical
