Thats good that you have the 1986, that means you should have the dome style piston and not the dished. Your ahead already.mccain wrote:Mines an 86 with 4300 miles on it. My moms boss gave it to her and she gave it to me, so I nick named it the Honda free. All I had to do was rebuild it.
I flooded the motor with the 68 jet, I'll try it again after I port it.
Milling the head of an 86 spree
- circusracer
- Goped
84,85,86 sprees: Intake mod, drilled pipe, .020" milled 1985 head, dome piston, 2mm raised exhaust port, sb50 reeds, 34mph average.
Re: Milling the head of an 86 spree
Depends on your objective. The advantage of paying a machinist to put it on a mill instead of hand lapping is that it will be true. It takes a steady hand and skill for hand lapping. Milling it down will increase compression ratio and power. How much is questionable. Remember though, increasing compression ratio requires higher octane as a rule.mccain wrote:Well if I can take away .020" for next to nothin' then I don't think im gonna' pay someone to mill a perfectly good head down.
I always used premium gas because I never knew what the scooter needed so I figured better safe than sorry. My neighbor has machinery that will allow me to mill the head true,
The bottom end of the motor went bad so now im rebuilding it. And to reference "circusracer". Your right the piston is domed!
I live my life a quarter pounder at a time, and for those 500 calories or more...im free.
- circusracer
- Goped
I have a 1985 and a 1984, so I had to buy the domed piston.mccain wrote:I always used premium gas because I never knew what the scooter needed so I figured better safe than sorry. My neighbor has machinery that will allow me to mill the head true,.
