Stereo install questions on 99 elite 50cc
The stator runs your lights and charges the battery, the amp draws over 300 watts(it cant be 100% efficient), 300 watts at 14.4 volts is 20 amps, correct me if Im wrong but the elite calls for a 7 amp fuse for the WHOLE electrical system.
Back to some speakers from a pair of beat up headphones in your helmet. It would be like wearing headphones, self contained, and legal.
http://www.hondaspree.net/phpBB2/viewto ... s&start=15
Theres some good info in there for you from a guy that has actually done it on an elite and knows that it IS possible. It sucks that the pics don't work though, his fiberglass enclosure was pretty cool.
Kenny_McCormic wrote:The stator runs your lights and charges the battery, the amp draws over 300 watts(it cant be 100% efficient), 300 watts at 14.4 volts is 20 amps, correct me if Im wrong but the elite calls for a 7 amp fuse for the WHOLE electrical system.
I have bolded the CORRECT information. Thank you very much.wiguy05 wrote: The speakers should sound good. It is 300 peak watts x 2 channels @ 2ohm.
Those speakers are 4ohm's a piece so they will be running 75w peak x 2 channels.
Thus, you will only be experiencing 37.5w x 2 @ 4ohm. This is very similar to a standard aftermarket head units output.
I do not know the output amperage of the stator on mopeds, so your guess is as good as mine in this case. My guess would be that it would be alright.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
- FTP 140cc Kit
- Lifan 90cc auto
- SpyderMike
k im bringing this thread back cause i just got an idea for my own scoot
as im sitting here reading info and listening to free music (thanks myspace) i started to think of ways i can listen while i ride
well i think i can listen while i ride the same way im listening right now
my computer came w/ a set of JBL platinum speakers and i wondered how to adapt them for the scoot, well the speakers take a normal headphone jack and plug into my power strip under my desk, and the wall wart takes the 120vAC and transforms it to an output of 12vDC @1a
now i may be wrong but im pretty sure the scooter could keep up w/ an output like that
anyone else think this will work? anyone else tried this set up before and know whether or not it works?
i happen to have another set of the exact speakers in my basement right now thanks to a warranty return of my computer minus the speakers
