Bystarter spring location?
I suppose you have checked the screen in the bottom of the tank?
If not go there. otherwise see if there is good vacuum at the vacuum hose where it plugs onto the gas valve. like make sure there is some gas in the carb and start the engine while you have a gauge on the line. don't know how much is normal but you know 5lb will work, see if you got that much. otherwise ???????
Well, I've been through that checklist at least twice and everything seems to check out OK. I replaced the vacuum line and the fuel line, the latter with clear line and no filter. The thing runs great (35mph after whittling out the intake manifold) but a bubble is forming and getting larger in the fuel line. We'll see what happens when it reaches the carb.
It occurs to me that it COULD be a lack of vacuum from the carb like Wayne says. But the problem stiill occurs even if I plug the fitting on the carb and manually draw 10-15 lb of vacuum with the tester while running. I can't see how that could be a carb problem. I just dunno. It's weird!
Old petcocks will get "sticky" sometimes, and need more vacuum than the engine provides to initially open. After cleaning the tank and petcock per tech docs, spray some WD40 into the vacuum side of the petcock. This worked to unstick mine. The in tank filter also clogs sometimes. An acid clean will fix this if you can't remove it (I couldn't without destroying it.)
If you've got a rusty tank (even once cleaned,) plan on running an inline filter, unless you like cleaning carbs all the time.
Here's where things get kinda hincky. Under that exact test, the flow comes and goes..............................OK one minute, no flow the next The tank is clean, the screen is clean, the valve is clean and opening with slight vacuum applied (off the tank), both lines replaced, with filter, without filter.............................everything. I figure it's GOT to be some intermittent sticking of the valve. But it doesn't respond to my ultimate test......................rapping on it with a screwdriver handle while motor running
Yep........................full. I'll try that, Wayne. What have I got to lose. The bubble got bigger and bigger............................let's just guess how THAT "movie" will end
. Another thing it occurs to me to try.......a bigger fuel line. Maybe the engine vacuum is enough to open the valve, but not enough to draw enough gas. I really hate these crazy kinds of mysteries.
I've always got a "bubble" in my fuel line. As long as the carb isn't running out of gas it's all good.
Sounds about right. I have a filter about 1/2 way b/t the fuel tank and carb. Anything above the filter is usually air.
