this is marc
beefy
Post by beefy »
Speaking of elite es does any one know if this kit will fit on one thanks.
tazland001
h
Post by tazland001 »
this kit will fit on the elite e also. I looked for a variator off one of my honda pals and it did not work on the spree. There are two engines on pal one with a longer crank shaft. That is the one with the variator. The other pal has the same single peice like the spree. Too bad :cry:
toboggan
Post by toboggan »
Would it be possible to try and machine a new variator?
toboggan wrote:Would it be possible to try and machine a new variator?
I'm not sure there's enough room to make one fit.
What's the smallest off-the-shelf variator out there? I've heard the Express had a small one.
Clivester
Re: h
Post by Clivester »
tazland001 wrote:this kit will fit on the elite e also. I looked for a variator off one of my honda pals and it did not work on the spree. There are two engines on pal one with a longer crank shaft. That is the one with the variator. The other pal has the same single peice like the spree. Too bad :cry:
Marc:
Do you know if the crankshaft is the only difference between the 2 Pal motors?
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
beefy
Post by beefy »
I was wondering the same thing if I could swap my elite e crank shaft for a Canadian pals and have a variator that would be sweet.
tazland001
Like I said one of the pals(AF12 is model number not engine number)) has a extra wide kick starter cover and a longer crankshaft(on variator side) so that honda could use a variator with rollers in it, but everthing else is identical to the the elite e. Now the the other pal engine is identical to the elite e engine. I have a pal but it is the has the shorter crank shaft. That sux. Now the pal engine will easily fit on the spree. the motor is just a touch longer, but that is the only difference.
And yes you can use a pal crankshaft in a spree no problem at all. As long as it is the short one.
Re: h
Clivester wrote: Marc:
Clive.
I know what you're thinking; keep in mind you'll need to run down a sidecover, parts of the starting assembly, and then need to modify the clutch to accept the whole thing. Most of these would be hard-to-find Pal parts. KeithW went down this path briefly and concluded, like most of us, that it's just easier to swap in a more commonly available Elite engine.
tazland001
?????spree variator and aero50 bore kits????????????
I am sending two spree engines to two of my parts makers this week. I will see if they can find a variator that will work on the spree. Don't get to excited because there is hardly any room for a variator. I am also trying to get some 44mm aero 50 kits in. Does anyone make a 47mm for the aero 50? What is the biggest bore kit for the aero 50?
Biggest bore kit is 65cc, so whatever that works out to with the factory stroke. Spree should be able to accept the same size (65cc) with case porting to match the cylinder.
Variator will be very limited throw: something like 0.1", which is all the the factory starter ring will take given the factory pulley bevel. This is based on my measurement of the maximum amount that can be removed from the larger steel '87 inner pulley. This inner pulley pretty much uses up all the packaging space; a variator would have to be around the same size. It would still be better than what is on there currently. Keep in mind you'll also need to come up with a new rear main clutch spring.
scooterwerx
Post by scooterwerx »
both the polini and malossi cylinders for the aero 50 are 47mm, i have a overbore piston on the way from europe that is 47.8mm, the standard one is 47.0, i have verified it with mitutoyo digimatics.
DandyDan
Post by DandyDan »
My understanding is that variators are only about 80% efficient at power transfer, so despite the improvement in acceleration it might be better to stick with a single speed setup if you really want to get to high cruising speeds.
tazland001
47mm
yah there's not much room for a variater. As to the cylinder, there should be no reason not to get a 47mm for this casted. As stated prior the cylinder will be bigger and there might be some serious shroud fabrication. well c.
xsh0rty
Re: this is marc
Post by xsh0rty »
hey marc, i jus got one of your bore kits through ebay, i was wondering what jet i should get for my carb. its for an 85 spree, doono if that makes a difference. thanks
turtle13
Re: this is marc
Post by turtle13 »
any word on the aero kits? I would really like the displacement of a polini, but not the price...
'62 125cc Honda cub
