Adventure Power Battery--> anybody used this?
Lunytune
Re: Adventure Power Battery--> anybody used this?
Post by Lunytune »
Eft37 wrote:So, how's that Adventure Power battery holding up?
I'm in the market for 2 batteries, 1 for the Elite E to be sold & 1 for my S.
Also, if you leave the switch in the on/run position, does this drain down the battery?
I found the right battery at Walmart of all places, for $40.
If you leave the key turned on it will run the battery down. The switch by the starter button is a kill switch, not a real switch.
Eft37
Post by Eft37 »
What was the model # on the WM battery, same one for your SA50 & SB50?
Lunytune
Post by Lunytune »
Eft37 wrote:What was the model # on the WM battery, same one for your SA50 & SB50?
Just happened to have the tickertape in front of me. It's an ES4LBS. It's a glove fit identical, made in Taiwan.
Accolay
Post by Accolay »
The battery is great!*
*I have only had the battery installed while the scoot sits in the garage, hungry for parts. I've only used it for T/S electrical problems.
