Page 2 of 2
Re: Adventure Power Battery--> anybody used this?
Posted: Mon Aug 10, 2009 4:32 pm
by Lunytune
Eft37 wrote:So, how's that Adventure Power battery holding up?
I'm in the market for 2 batteries, 1 for the Elite E to be sold & 1 for my S.
Also, if you leave the switch in the on/run position, does this drain down the battery?
I found the right battery at Walmart of all places, for $40.
If you leave the key turned on it will run the battery down. The switch by the starter button is a kill switch, not a real switch.
Posted: Mon Aug 10, 2009 4:49 pm
by Eft37
What was the model # on the WM battery, same one for your SA50 & SB50?
Posted: Mon Aug 10, 2009 5:21 pm
by Lunytune
Eft37 wrote:What was the model # on the WM battery, same one for your SA50 & SB50?
Just happened to have the tickertape in front of me. It's an ES4LBS. It's a glove fit identical, made in Taiwan.
Posted: Mon Aug 10, 2009 6:40 pm
by Accolay
The battery is great!*
*I have only had the battery installed while the scoot sits in the garage, hungry for parts. I've only used it for T/S electrical problems.
