New 44mm bore kit....now what?
Re: New 44mm bore kit....now what?
rolinlowna96 wrote:ok i understand that i need gears to make it faster but with a new bore kit i should be going faster then 30miles and hr,,at least 35 it did 30 with out bore kit
Try using no air box and see if the acceleration improves. The 44mm big bore does not like the restriction of the stock air box no matter how many holes you put in it.
If no airbox/filter is an improvement over swiss chees air box, get a uni filter, it should help.
Also check for carbon build up in your exhaust pipe. It might be time for the campfire treatment. :surprise:
If you were going 30mph before you will still only go 30mph :sad: But it should get there quicker :smile:
What size tire do you have? What size is you friends tire?
Different year sprees had different gear ratios. Is you friends spree newer than yours?
No, not true. Unless the engine turns more RPM, top speed will not increase regardless of displacement increase. To make it turn more RPM, listen to TJ.
Again you have no understanding of what it is that makes a vehicle go faster. :eyeroll:
rolinlowna96
Post by rolinlowna96 »
thanks for the help guys your right im new at this had one back in the day but never had to work on them...i had a friend do most of the work...........traffic jam tire size is 2.50 and his is 2.50 same year your right on getting frustrated will try the no airbox next to see what happens so if i take my muffler off and campfire it,,it will burn all junk out if any in it.. ok now on the bystarter does it work as a choke....when i start it now it kinda wants to stall but once warm it fine
rolinlowna96 wrote: ok now on the bystarter does it work as a choke....when i start it now it kinda wants to stall but once warm it fine
The bystarter is an electric choke.
Check for leaks around the bystarter where it fits into the carb.
An air leak around there could cause the problem you described.
:peace: Keep on rolling low.
rolinlowna96
ok now im gettin little * sorry for the mouth but getting tired of this moped...ok at first i ordered the 44mm bore kit had it put on got it to 30miles and hr no different then what i was doing stock don't take this the wrong way im not bashing anyone so don't reply stop bashing and you no who you are..ok now back to 44mm bore kit put it on got it to 30 sometimes 32 cold days 28 mpr...then you guys say i can't go any faster without the gears ok so i ordered the gears put them on i seen 35miles and hour once put them on lastnight today i go to ride it wont make it to 25 gets hot as * shuts off and won't not start back up acting like it was locked up couple mins later fired back up now i can get it back started put load on it shuts off...now before i did the gears moped ran fine now i put gears in runs like crap and dont wanna stay started...anyhelp would be nice...here is my number if you would like to call....313-978-0917 mike
You can't go any faster because you failed to acquire the gear set with the BBK.
toad772
Post by toad772 »
rolinlowna96 wrote:ok now im gettin little * sorry for the mouth but getting tired of this moped..
You mean scooter...
Sorry couldn't resist.
PS3 it only does everything.
fastplastic
Post by fastplastic »
1. did you refill case with oil when you replaced gears?
2. did you check engine for vaccum leaks?
3. what air filter or air box configuration are you running?
4. have you done anything to clean out your pipe?
5. did you install a new jet in your carb with the bbk?
