Looking for Scooter Mechanic in Michigan
Re: Looking for Scooter Mechanic in Michigan
Post by swimmingfree »
well let me be the first to say hello and welcome to our world ...lol it fun a wise man said once " It's more fun to ride a slow bike fast, than a fast bike slow. " lol
I spit the case today.
I used a steering wheel puller. It worked really well. :2thumbs:
Still had to smack it out the other side with a rubber mallet. :wink:
With the case split, and the crank out, I decided to open up the intake on the block.
Here are a couple before shots.
In progress
All done
I will need to try and fix this :eyeroll:
OneBulletDan
Post by OneBulletDan »
Had the same problem with the `99 I`m rehabing. The bolt somehow had been snapped off even deeper in the case. Tried drilling a hole in it, using Bear`s Mystery Concoction and an easy-out on it. Wouldn`t budge. Wound up using progressivly larger drill bits until I got to the tap size, and then used a 8mm, 1.0 thread tap. 45 minutes after I started, the world was lovely again. Two new 8X35 bolts and it`s good to go.
fastplastic
Post by fastplastic »
OneBulletDan wrote:Had the same problem with the `99 I`m rehabing. The bolt somehow had been snapped off even deeper in the case. Tried drilling a hole in it, using Bear`s Mystery Concoction and an easy-out on it. Wouldn`t budge. Wound up using progressivly larger drill bits until I got to the tap size, and then used a 6mm, 1.0 thread tap. 45 minutes after I started, the world was lovely again. Two new 6X35 bolts and it`s good to go.
sorry had to correct...
OneBulletDan
You should be!
95701-08035-07 BOLT, FLANGE (8X35) $1.67
Re-corrected! :smile:
fastplastic
99% right :oops: didnt relize that was the exhaust bolt... but still its a 8-1.25x35 :thumbwink:
Installing the crank.
That is all for today......let the honda bond dry :2thumbs:
OneBulletDan
fastplastic wrote:99% right :oops: didnt relize that was the exhaust bolt... but still its a 8-1.25x35 :thumbwink:
So THAT`S why I had to use my three pound spark plug hammer to put `em in! :evil:
Yep, I checked. You were right on the pitch. Guess between the two of us, we`ve got a brain. :smile:
fastplastic
the jury is still out on me lol... :confused: now, to figure out how to rob tjamz for that malssoi crank hmmm... :twisted:
jcivince
Post by jcivince »
No robbing allowed!!!!! (I think noiseguy should post a stickey on that)
fastplastic
jcivince
Post by jcivince »
fastplastic - To answer your question/explain, you posted that you were trying to figure out how to "rob" the Malossi crank from tjamz. The crank happens to be mine - tjamz is repairing/upgrading/assembling the scooter for me. Thus my comment about no robbing allowed as you would be stealing my crank.
The portion of my post regarding having noiseguy post a stickey about no robbing was a joke - there is a stickey out there about no threats on the board and was trying ask for a similar stickey about robbing/stealing.
jcivince
Post by jcivince »
All strictly for humor, of course. But it appears my attempt at humor was not very sucessful....
