LMH
Re: 2000 Mystic Purple Elite build 74.6 MPH
Post by LMH »
Kymco zx50 is the only one I feel safe doing 65+ really. Even at 60+ it's hairy. Check out my kymcoforums account: lovemykymco.
LMH
Post by LMH »
Also for your first ever scooter build and ownership, you have a killer awesome machine! Envious by everyone!
paulpauly7
Post by paulpauly7 »
Very nice work indeed .Ive hit 71.3 mph on my spreedio as in sig it could go faster but ive tuned it now for 0-55mph to be over the top fast for round town .
ped
Post by ped »
Hi cruz. very nice tuning. I like this build, very nice. :thumbwink:
cruzingratiot
Post by cruzingratiot »
just riding and buying parts
if you have a NCY caliper
ebc pads will fit the top smaller holes are not used
NCY 1000-1314 Brake pads
EBC SFA193HH
EBC FA193
just getting the parts together for front end swap
5339 miles on odometer
Donate Life
http://www.donatelife.net/
Thank You
LMH
Post by LMH »
That's some good part matching! I'm going to buy a spare set as well, I'm thinking I need to order another front end set up from g9.
cruzingratiot
spark plug wire end
what do you use ??
90 deg
NGK LD05FP
#8070
or
NGKLD05F
the P means it has water tight ends
the red end is what came with my coil
and a 8mm Dyna wire
Donate Life
Thank You
cruzingratiot
did 3 runs yesterday
changed to red contra spring
because
( the yellows last about 300 to 500 miles and than drop about 1000 rpm at crusing speed
and takes the bike out of the power band)
1 =73.3
2=82.4 didn't take pic
3=85.2
all in the 10900 rpm to 11200
the 80+ were about a hour or so apart on the same road
the bike runs totally different with the red spring
and the drum brakes are useless
need to get moving on the disc brake swap
93 Octane fuel , (R+M)/2.
8.5 gears
24mm Polini pwk carb 128 main jet 45 pilot jet
JJH CARB needle clip on top
new malossi red contra spring 2000 RPM
variator weights 27 grams
polini 3 shoe clutch
naraku clutch bell
Windjammer exhaust
polini corsa 72cc
malossi crank
32-1 premix Klotz r-50
Donate Life
Thank You
curtis966
Post by curtis966 »
Very Impressive. Fastest top speed I've seen on here especially at 72cc. Great build with some awesome tuning info!
ped
Post by ped »
hi Cruz. excellent tuning. very nice job. Great thread. :2thumbs:
LMH
Post by LMH »
8.5s and 85 mph, not sure any one has ever done that regardless of cc. The math is a little fuzzy there. Pretty cool either way. At 86 mph I'm at 12.8k with 6.91 on a full mhr kymco zx50 block and a 120/70-12. At 81 mph I'm at 11.9k.
maybe there's a lot of belt slip I haven't noticed. How's your clutch? I know mine are toast after a few top speed runs.
bonesv
Post by bonesv »
12 mph jump between runs on same day at that speed. lol Now that's tuning!
dabinonahonda
Post by dabinonahonda »
so jelly i wish my scoot was done
1988 hd sportster 883 evo
1983 hd sportster 1000 roadster
2001 Honda elite s
AIO MotorSportS
Post by AIO MotorSportS »
hi,really good numbers,I'm ready start from the other side,build the stability of the bike first and the way to stop it with NCY front end for ruckus, 220mm rotors,and ncy rear rim,both with a 90/90/10 conti tire,geeting really low profile tire because the 4" rim wide,yys 230mm suspension,Now I'm start with the engine,hope can meet you number somehow :bowrofl:
kauaianman
Post by kauaianman »
wow action ah!
couple questions...
what pulley/ramp?
what is crusing temps/rpm at 50mph with that tune?
how much do you weigh?
nice job!
