Checkin in, first post... here at least
KingJeff801
Re: Checkin in, first post... here at least
Post by KingJeff801 »
Dude that filter is gonna suck ....The Uni will work way better :imo: . great build by the way :thumbwink:
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
Quoth KingJeff801:
I disagree. Oiled Cotton works just fine. Bakaracer is selling some Kovered Kosos all the Kool Kids use. If you switch from one to the other, the carb may require re-jetting is all.
The only advantage to the UNI is that it's cheap and perhaps a bit lighter, so it doesn't stress the carb mount as much over bumps.
KingJeff801
The one I got with my carb kit was built very poor. This just might be the one from autotech ? but I wouldn't use it on my bike :imo:
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
I have had no problems with those filters with under 80cc setups.
But 82cc and up just would not run right, no matter what my jetting was.
KingJeff801
Mine literally fell apart. Maybe I got a lemon
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Chicago Ben
Post by Chicago Ben »
KingJeff801 wrote:Mine literally fell apart. Maybe I got a lemon
:confused:
dang.
Well in better news... found a guy to powder coat my met wheel and crank covers... so sending parts out again
CPS Powder Coating
http://www.cpcpowdercoating.com
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
KingJeff801
Was it very pricy? Are you just doing your front and back covers ? or both rims too?
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Chicago Ben
KingJeff801 wrote:Was it very pricy? Are you just doing your front and back covers ? or both rims too?
ehh more than I want to pay but hes going to media blast them first
$100 for the front and back crank cover & rear wheel
(my front wheel is basically new)
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
KingJeff801
That's not too bad. What color did you decide on?
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Chicago Ben
I'm going with white
I figure, the crank cover white, the shock white, all the unpainted trim will be OEM refresh sprayed black then the body work will be white
I want this thing to look factory as possible... other than the giant pipe ... and sounding like 10,000 weedwackers flying down the street
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
sent out crank cover + rear met wheel to get powder coated today
I'll keep you guys posted how it turns out
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Post by eliteguy50 »
I have yet to find a shop that doesn't blast them before paint. It is part of proper prep. Does anyone sand rims anymore?
No commercial shop that's for sure, to time consuming.
eliteguy50 wrote: Does anyone sand rims anymore?
No, but I've "salted" a few lately
Chicago Ben
so here is a good question
I bolted up the stock plastic shroud that covers the jug/head for air flow
since the bbk... is so... big, the shroud is touching the head
is the shroud going to melt? is this bad?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
