You may not know that the Turbo was tied with the GPZ1100 for the Fastest Production Motorcycle money could buy. Cycle World's radar clocked both at 144 MPH. Liquid-cooled bikes just a couple of years later made both hopelessly obsolete, but I remember drooling over the svelte, compact (for its time), and ultra-sophisticated 750 Turbo. How far we have come.
curtis966
Post by curtis966 »
cruzingratiot wrote:after 5+ months the rear rims arrived
pre ordered from jiangwayne.com july 24
received front rims sept twenty something
jiangwayne had a problem with rears wrong spline count
that is why it took so long to get rears
when I pre ordered and saved $ 21.00 on each rim 84.00 total
and a break on shipping so it was worth the wait to me
Part numbers front has 12 mm axle
RPM 10"x2.15J Front Wheel (Dio TDM, Black) - 44650-GW0-R02B
RPM 10"x2.15J Rear Wheel (Dio, Black) - 42601-GW0-R02B
was going to use the rims I had but like the looks of the straight spokes better
probably going to sell since i bought 2 sets of the other ones
What it's this set of forks from? And did it come with the disc and nyc caliper or did you add them?
cruzingratiot
Post by cruzingratiot »
they came on a parts bike I bought
viewtopic.php?f=20&t=27850&start=90#p250532
Donate Life
http://www.donatelife.net/
Thank You
cruzingratiot
TO WOHM IT MAY CONCERN
Not Funny
if I find something posted on craigslist again
especially with my information
I will delete all my posts
Signed ME
Donate Life
Thank You
cruzingratiot
graphite9 wrote:
cruzingratiot wrote:TO WOHM IT MAY CONCERN
Not Funny
Signed ME
what happened?
Someone posted my elite for sale
with a picture from here
with my phone # and name
and copied info from my posts
That is all I am going to say
Donate Life
Thank You
Rip_City_Spree
Post by Rip_City_Spree »
That's kinda fu ck Ed up man.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
ped
Post by ped »
sounds like a scammer trying to scam someone?
craigslist has a ton of scammers.
bonesv
Post by bonesv »
Just sounds like someone you know having a poke at you in a twisted kinda way. I must say I like the hot pink foil paint job, but the baby blue wheels and the sick exhaust color....please.
Sorry, but it does not seem like a scam posting. :bs:
ped
Post by ped »
I don't know? someone trying to sell his bike? That's not cool.
+1 on the color.
cruzingratiot
what does it take to fit a dio style triple tree
here is the start
a lot more to do
initial fitting
clearance for left turn
going to add support to cut out brace later cant weld in house
Donate Life
Thank You
cruzingratiot
graphite9 wrote: RRGS or NCY legs. DON'T do the kn webike ones. I hate mine. They lockup, and actually have slop front to back. I'll be switching to ncy this spring.
the forks in this pic I think are NCY
which are stock length dio style
they are not the forks I am going to use
but are in this picture just for mock up
I have a set of all black NCY forks stock length will post pic later
with 220mm rotor caliper ect
Donate Life
Thank You
Xxbeejay45xx
Post by Xxbeejay45xx »
A lot more cutting of plastics and welding to clear the turning radius at the front panel bolts. It's never a easy mod for disk setup. But once it's done right it's sick!! Keep up the good work, and Thais for sharing your build.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
cruzingratiot
I am going to bounce back and forth on what I do
so what do you do for a throttle, mirror mount, and master cylinder
and will it fit inside the plastic or will you need to cut ?
there are other ways to do this this is the way I came up with
I am going to use the stock throttle ,brake lever mount,mirror mount and mod it
with a gy6 style master with a bottom outlet and sight glass that you can see from the handlebar end
mirror mount g.jpg (226.46 KiB) Viewed 7378 times
a cut out on the metal piece that holds the faring will add gusset to left side later
fits in just need straight brake line outlet
Donate Life
Thank You
cruzingratiot
this is one of the reasons i chose this master
you can see the sight glass from handle bar end
sight glass.jpg (230.44 KiB) Viewed 7378 times
the master fits under the covers and the mirror works also
mirror cover.jpg (242.14 KiB) Viewed 7378 times
Donate Life
Thank You
ped
Post by ped »
very nice work Cruz.
