pure beauty, dude... you have one sweet pipe on your hands! i love it man- and just think; it's the only one in the USofA. i can't wait to hear how it performs and sounds.
Thanks for sharing-
Later man, jon
>< Solitaire Unraveling >< http://www.youtube.com/watch?v=U45NfWSX-Vk
...my life story
bakaracer wrote: that stinger pipe is really long and the belly diameter is not so fat.
that J is pretty big though.. the length of the U area where the silencer mounts is really long. looks like this should be a good mid range pipe .. belly is small this thing will hit hard and may be loud as the baffle looks to be late in the belly.. should be fun I see no hesitation in any of the rpm bands
put it on your ZX NOW!!!!!!!!! and post a vid I wanna hear it
I'm sorely tempted to bolt it on now, but I'm leading a 40 scoot ride through the hills of Austin this weekend, and won't have time to get to it until next week at the earliest.
sanjuro wrote:I'm sorely tempted to bolt it on now, but I'm leading a 40 scoot ride through the hills of Austin this weekend, and won't have time to get to it until next week at the earliest.
cool, yeah and you'd probably have to retune for that pipe also, I'll be keeping an eye out for a video though
It's running perfectly right now. The temps are right where they were last time, and there is no stumbling or hesitation.
I'm thinking about going down to 6.0 gram rollers since I have the 7.0 gram ones in now. I want to see how the bike reacts to the reduction of roller weight.
Another thing, I am using the Malossi torque converter, and am thinking about switching the 'pins' to the alternate location to see what difference there is.
In a couple of weeks I'm going to try out the Burial exhaust even though cylinder won't be matched to that specific exhaust.
don't do to many changes at once.if your dropping to all 6grams ,that alot of weight at 1 time.do it 1.5gram increaments.or 3 grams total weight change.6 is way to much.You should get some polini or malossi weights that have those off weights like 6.7g or 7.4g rollers.then you can mix them with the straight gram rollers and you can change your weights in .5g to 1gram increaments.then you can really dial that bike in.
Last two weeks have been hectic planning a 40+ ride thru the hills of Austin TX. Lot's of Honda and Yamaha scoots, with my bike making an appearance at 3:15.
Wow! that looked like a fun ride.How did the bike run?
My bike was running perfectly Thursday, but friday was 10 degrees warmer and the bike would not idle so I had to keep the slide open at the lights. That evening before one of the rides I put in a 37.5 slowjet and got the idle problem under control. The test of the weekend was perfect.
