PITA though...I'll do that tomorrow, it's 9PM here.
Thank you very much for all the advice. I'll keep in touch.
If the bike starts cold and then dies after 2 minutes, it's a blocked idle jet. The rest of the information is superfluous, but note you can get the bike running on the stand by restricting airflow, which makes bike pull gas from bowl through main jet. The engines will do all sorts of other odd running behavior on stand that they won't do with wheels on ground, so not a good diagnostic.cancunia wrote: Wed Sep 26, 2018 3:12 am If the engine dies at full throttle when you take your finger away, is that still the idle jet causing the problem?
It does sound like a fuel / air problem though. Are all of the joints tight between the carb & the engine, reed cage etc? Does the carb float move freely, and the float valve / fuel pipe unblocked?
Link doesn't work for me.
When I was shopping around for a scoot, my Suzuki dealer, who is also a Peugeot one and who I know from the beginning of the 90's, told me to stay away from these Ludix and Clip Peugeot : they are crappy. And I think he also told me they were chinese made. Nothing to see with the Honda/Peugeot ones from the 80's.cancunia wrote: Wed Sep 26, 2018 3:12 am
Last year I very briefly had a Peugeot Ludix.../..I sold the Ludix as soon as possible due to the terrible build quality, the engine was solid enough but everything else was shoddy right down to the bathroom style halogen spotlights that were fitted (as standard) in place of headlights.
Be careful using pressure tester because it only needs to be 6-7 pounds per square inch (whatever that is in metric terms) to see if it leaks out. A very slow leak-down is not necessarily indication of bad seals but a quick leak-down could be seals or other source; i.e. gasket or oil pump o-ring.GSX1400 wrote: Wed Oct 03, 2018 9:49 am I'll check that needle. Never touched it or took it apart.
A friend of mine told me to check the petcock : maybe gas coming through but not enough?
Also told me to check the 2 crank rubber gaskets. When I took the variator off the other day, the gasket was at its place and everything clean.
Told me to do a pressure test to be sure.
