My 2001 elite 50 build-up
aerorob
Re: My 2001 elite 50 build-up
Post by aerorob »
Yeah, I dialed in in with the a/f screw today and it runs excellent.
Before I adjusted it when the bystarter was on it was soo rich it almost flooded.
Thanks bakaracer!
aerorob
Post by aerorob »
So after about 150 miles of riding somewhat tame, I think I am going to start tuning it to run at a higher rpm.
Right now I have got my rollers at 8g and I would estimate about 6,000 rpm, pretty low, but about double the hill climbing ability of my stock bore.
I am going to drop to 7s today and see what happens.
aerorob
Post by aerorob »
I'm just not gettin the crazy wheely low end performance that I want, I'm thinking I might have rollers slightly off.
With my current setup, 1.5 k spring and all, what weight of weights would you use on your 72cc scoots?
sanjuro
Post by sanjuro »
I didn't think you could get easy wheelies with 9:1 gears unless you were running something like a 120cc cylinder kit.
bakaracer
Post by bakaracer »
accually you can just slightly out from take off.If you got the clutch tuned with the right springs and a good roller setup it will wheelie pretty good.
sanjuro
Post by sanjuro »
Sweet, that's good to know since I have 9:1 gears too. 8)
aerorob
Post by aerorob »
It almost wheelies, sometimes it even does, and then I let off in panic. Maybe ill step up to a 2k rear center and keep my 2k clutch grabbers. Would that be advisable?
To perfect Wheelie Technique and win the surrender of the Faire Damsels, it is good practice to keep a finger in the rear brake. You know, the left one. :) It's kept Wheelman from going all the way over a few times. :oops: Never test-ride a Buell XB12S after a couple of beers. Never mind, H-D shuttered the only interesting part of their Company...
Anyway, keep the throttle open and control the attitude with a very light pressure on the rear binder.
Wheelman R a Wheelie expert.
Official State Secret: EYES ONLY!
I ride Unicycles. Don't tell nobody... :naughty:
This Post will self-destruct in 5 seconds. That is all.
aerorob
Post by aerorob »
I took a spin on the elite, definately the longest ride yet, and power seems to be rapidly improving over already exceeding my expectations. 7grollers seem to be right for my setup with a lot of power pretty much everywhere.
Although I did a little speedo burrying today after about 160 miles, the bore seems to be breaking in quite well.
Thanks for everyone who helped out with info, couldn't have been done without you all.
One question..
The polini 72 cc has a 47mm bore, mine has 48, is this some sort of 73cc in between size? Haha.
losthope
Post by losthope »
aerorob wrote:I took a spin on the elite, definately the longest ride yet, and power seems to be rapidly improving over already exceeding my expectations. 7grollers seem to be right for my setup with a lot of power pretty much everywhere.
One question..
74.9 cc
808BMW
Post by 808BMW »
I pull wheelies all day with 6.9:1 gears, 9:1 should be easy as pie :P
aerorob
Post by aerorob »
Hey everyone, I. Really want a temp gauge for my elite, what do you guys use? Perferably something cost effective that I might be able to buy in store(not online)
Send me advice / links please!
Thanks
fightingplankton
Post by fightingplankton »
i have no valuable input
Last edited by fightingplankton on Mon Apr 05, 2010 10:51 pm, edited 1 time in total.
'86 spree
'86 aero50
'83 aero80
aerorob
Post by aerorob »
Thanks, I was searching for coolant head temp, not cylinder head temp, dur.
aerorob
Post by aerorob »
Changed my setup a bit and I am diggin it with my bore getting broken in,
Went down from 7g to 6.5
I'm also thinkin about changing to a 8 plug, I am using a 6 now, do you guys think its a good idea?
